Replacing GL1100 Springs - Page 4 - Steve Saunders Goldwing Forums
post #31 of 43 (permalink) Old 08-16-2010, 01:49 AM Thread Starter
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
Then stick a screwdriver or something through the bottom mount to prevent the seal and other parts from flyign all over the place.
I'd strongly recommend doing the next couple of steps outside or maybe in a large drain pan.
Cover the shock with several rags to help minimize splatter.
I only used one because this shock has no oil in it because it had been cleaned already, I only put it back together in order to get pictures for this write up.
P.G.R. Member ID: 88374
Broke Winger is offline
post #32 of 43 (permalink) Old 08-16-2010, 01:53 AM Thread Starter
Then use a small controlled blast of compressed air to push the seal and other parts out of the shock. Get a good firm grip on the shock while doing this. I don't have a grip on the shock because I had to hold the camera!
The parts will blow out onto the shaft. Pay close attention to how they come out so you know how to put them back.
post #33 of 43 (permalink) Old 08-16-2010, 01:55 AM Thread Starter
When installing the new seal use a length of 1.5 inch PVC tubing to drive the seal in place. Place the large outer washer between the new seal and the PVC tubing. I don't have a picture of this step, but it's pretty easy to figure out with out one.
Once the seals are out, then you put the shock int he rig compress it and remove the head. Once the head is removed and you decompress the shock it will pretty much fall apart.
post #34 of 43 (permalink) Old 08-16-2010, 06:22 AM
Broon452's Avatar
Model: 1988 GL1500 64000Km
Thanks for the info Broke Winger...Will reassemble and blow out the seal tonight. Hopefully all will go ok
Head down and bum up means you miss the scenery in Scotland ......SO.....Always ride in comfort (and style)
GL1200...sadly missed..34k
GL1000...nice runner...34k...Gone
GL1100...very fast.....58k...also gone
GL1100...show bike in process of restoration
GL1500 1988 64000km
1959 Velocette Venom...AND 1953 Velocette MAC...another retirement project
Broon452 is offline
post #35 of 43 (permalink) Old 08-16-2010, 10:23 AM Thread Starter
Glad I could help.
post #36 of 43 (permalink) Old 03-11-2011, 11:26 PM Thread Starter
I was just wondering, if I reorganized this writeup to start with the procedure to remove the oils seals, and cleaned it up a bit, would it be good enough to be put in the Biker's Workshop?
post #37 of 43 (permalink) Old 10-15-2012, 08:35 PM Thread Starter
According to BikeBandit Progressive Spring kit D does not fit the '82 Interstate. They are wrong. The kit fits ALL GL1100 models. Honda used the exact same Showa shocks for All the GL1100's
Not sure if it is the same kit for the GL1200's or not.
post #38 of 43 (permalink) Old 03-07-2015, 04:46 PM
Year: 1984
Make: honda
Model: gl1200a
shock rebuild
broke winger, just got my shocks apart using your compression tool. worked great. only problem is the rubber bushing on the piston rod is completely deteriated, its like bubble gum. are these avalible or should i leave it out.
weas is offline
post #39 of 43 (permalink) Old 03-08-2015, 03:13 PM Thread Starter
If you are using Progressive Suspension replacement springs just toss it you won't need it.
It's only purpose is to soften the impact if you bottom out, which won't happen if you use Progresssive springs.
post #40 of 43 (permalink) Old 03-08-2015, 06:19 PM
absolutely...
GL1100 clutch springs Cooter81gl1100 Goldwing Technical Forum 12 05-09-2012 06:38 PM
Springs, Springs, Springs... I need carb springs this spring! Mr Magic Fingers Goldwing Technical Forum 3 04-29-2010 08:27 AM
Fork Springs GL1100 Martin Fischer Goldwing Technical Forum 9 06-23-2009 10:29 AM
When replacing fork springs ? simonone Goldwing Technical Forum 10 07-30-2008 08:53 PM
progressive springs gl1100 Phils a winger at last Goldwing Technical Forum 3 05-23-2007 01:34 AM
