Replacing GL1100 Springs - Page 5 - Steve Saunders Goldwing Forums
post #41 of 43 (permalink) Old 04-26-2015, 11:18 AM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
smaller spring on 83 wing
In the second photo of the springs. Does the smaller spring slide through the white plastic cup?
I am replacing with Pro 00-1170 and the small spring will not pass through the cup. Is this correct? If not what should I do?
Progressive says this is the correct kit for my bike.
Originally Posted by Broke Winger View Post
Now decompress the shock and remove from the rig.
At this point the shock will come apart and look like this, only tours will be oily.
Wilcoy02 is offline
post #42 of 43 (permalink) Old 04-27-2015, 01:20 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Both of mine were tight going into the plastic cup.
One was so tight it finally seated when I compressed the shock.
JeffMayfield is offline
post #43 of 43 (permalink) Old 09-10-2016, 02:33 PM
Year: 1982
Make: Goldwing
Model: 1100
Good post. I have to replace the springs in mine asap,before cold weather. Thanks
sindust1967 is offline
GL1100 clutch springs Cooter81gl1100 Goldwing Technical Forum 12 05-09-2012 06:38 PM
Springs, Springs, Springs... I need carb springs this spring! Mr Magic Fingers Goldwing Technical Forum 3 04-29-2010 08:27 AM
Fork Springs GL1100 Martin Fischer Goldwing Technical Forum 9 06-23-2009 10:29 AM
When replacing fork springs ? simonone Goldwing Technical Forum 10 07-30-2008 08:53 PM
progressive springs gl1100 Phils a winger at last Goldwing Technical Forum 3 05-23-2007 01:34 AM
