Bringing back a 1983 Aspencade after sitting in shed. - Page 28 - Steve Saunders Goldwing Forums
post #271 of 344 (permalink) Old 09-07-2010, 09:04 PM
MDKramer's Avatar
Model: GL1100 / GL1200
Oh Glory Be!!!
Hey Copper! Look what's back!!!
Way to go Steve, and a special thanks to Jim!
Mike Kramer
"Learn from the past, set vivid, detailed goals for the future, and live in the only moment of time over which you have any control: Now."
Denis Waitley
MDKramer is offline
post #272 of 344 (permalink) Old 09-07-2010, 09:25 PM
Yea!!!!!
glory be is right. Thank you Jim....
This is great.
Hal, now you can rest in peace.
post #273 of 344 (permalink) Old 09-07-2010, 11:40 PM Thread Starter
copper204's Avatar
Model: GL1200A
Send a message via Yahoo to copper204
Holy smokes ...wowwwww wow wow.. I better get too updating..
Thank you Steve and John and Jim..
Another donation will be on its way.
Hal
Ok as a celebration.. I am in a great mood... So who needs some free GL1100 parts... Take it easy an PM me up.. The first Five can have some freebies...
Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE\'S AWAKE"
and
copper204 is offline
post #274 of 344 (permalink) Old 09-08-2010, 12:08 AM Thread Starter
copper204's Avatar
Model: GL1200A
So I started back on working on the brakes. I cleaned em up and honed out the brake calipers with this neat little hone.
and
post #275 of 344 (permalink) Old 09-08-2010, 12:11 AM Thread Starter
copper204's Avatar
Model: GL1200A
Here are the new caliper seals and dust washers order form and packing label. These are 1983 Aspencade specific. this being due to the integrated front and rear brakes, the right front brake and rear brake use the same seals. they are also inter linked via the rear brake pedal.
and
post #276 of 344 (permalink) Old 09-08-2010, 12:15 AM Thread Starter
copper204's Avatar
Model: GL1200A
And here we have one of the calipers all cleaned up and new seals and dust seals installed. It is tricky and frustrating.. Just take your time. The trick is too bend seal in half and insert one side and slowly walk the seal into the caliper using a tooth pick being careful and slow. they will fit in nice and snug. Just make sure and clean out the grooves. I used a brand new battery terminal cleaner and worked like a charm. then i honed caliper and cleaned it up for tenth time and installed the seals and dust seals.
and
post #277 of 344 (permalink) Old 09-08-2010, 12:17 AM Thread Starter
copper204's Avatar
Model: GL1200A
And here is the right front side with pistons re-installed. Just a tad bit of assembly grease and they slipped right in nice and firm.
and
post #278 of 344 (permalink) Old 09-08-2010, 12:21 AM Thread Starter
copper204's Avatar
Model: GL1200A
And here is the left side. Notice it is larger than right side and rear brake. This is the caliper that is directly operated by the front brake lever. Also ensure the slider of the caliper moves freely. This is the slider next to my pinky finger. If it does not move freely your brakes will stick and squeal no matter how clean everything else is. And all the anti squeal material will not stop squeal till this is free. This is due to the fact the caliper binds and does not float as it was designed.
and
post #279 of 344 (permalink) Old 09-08-2010, 12:25 AM Thread Starter
copper204's Avatar
Model: GL1200A
And here is a fully assembled caliper. I NEVER EVER EVER use any of the brake pad glue garbage. If your brakes are clean and properly lubed it is not needed.
and
post #280 of 344 (permalink) Old 09-08-2010, 12:28 AM Thread Starter
copper204's Avatar
Model: GL1200A
See this metal clip. Make sure it is there and in good condition. This also can cause brake squeal. This due to the fact the brake caliper can shift in position. I cleaned it on all of em and tightened it and re-installed.
and
Bringing an 84 Aspencade back to life after 20 years Fusionenterprise Goldwing Technical Forum 17 05-15-2015 07:39 PM
Bringing an 83 GL1100A back to life, Sure can use some help Sd455 Goldwing Technical Forum 13 10-29-2011 07:08 PM
Bringing a GL1100 back from the dead john_51 Goldwing Technical Forum 6 04-04-2010 09:20 AM
Bringing back faded paint? flashya2 General Motorcycle Discussion Forum 8 11-09-2008 11:43 AM
Bringing a LTD Back to Life RedWinger Goldwing Technical Forum 29 02-27-2007 07:04 PM
