Bringing back a 1983 Aspencade after sitting in shed. - Page 9 - Steve Saunders Goldwing Forums
post #81 of 344 (permalink) Old 05-22-2010, 12:31 PM Thread Starter
copper204's Avatar
Model: GL1200A
Send a message via Yahoo to copper204
OK OK I will get some and try it on one of my parts bikes..
Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE\'S AWAKE"
and
copper204 is offline
post #82 of 344 (permalink) Old 05-22-2010, 01:18 PM
MDKramer's Avatar
Model: GL1100 / GL1200
You won't regret it.
I bought the 5 gallon bucket of the gel solution because I knew it wouldn't be enough to fill the tank, I wanted to use compressed air to splash the gel up onto the top surfaces. It worked, but was a pain in the back-side.
For the 2nd tank, I took a tip from a member here, and went to Walmart and bought those cheap punch balloons with the big rubber band...Insert the balloon through the fuel gauge pickup hole, inflate with compressor until the solution is about to come out of the fill neck, tie off the balloon, walk away, and come back at the prescribed time.
When you're ready to empty the tank, pop the balloon, grab your shop-vac and suck it all out.
Rinse well, dry with compressed air, inspect...ou should be all set.
Mike Kramer
"Learn from the past, set vivid, detailed goals for the future, and live in the only moment of time over which you have any control: Now."
Denis Waitley
MDKramer is offline
post #83 of 344 (permalink) Old 05-22-2010, 03:55 PM Thread Starter
copper204's Avatar
Model: GL1200A
Stores on the west coast that might carry it?
and
post #84 of 344 (permalink) Old 05-22-2010, 09:00 PM
MDKramer's Avatar
I'm not sure it's sold in stores. I think the only way you can buy it is direct from the manufacturer.
Mike Kramer
Denis Waitley
MDKramer is offline
post #85 of 344 (permalink) Old 05-22-2010, 10:56 PM Thread Starter
copper204's Avatar
Model: GL1200A
Ok I will do a search and try to find it... Hal
and
post #86 of 344 (permalink) Old 05-22-2010, 11:07 PM
redbaron's Avatar
Model: GL-1500
Copper I'm reading your posts and you made a comment about a Baking Soda Blaster, but I haven't seen you post any pictures of it......I would like to have a tool like this to clean my carbs, a They need rebuilding and this "blaster" did a great job cleaning your carbs up......
Honorary member Wild Rhinos
redbaron is offline
post #87 of 344 (permalink) Old 05-22-2010, 11:11 PM
dbd123's Avatar
Location: Singapore + Lake Placid, NY, mostly..., , Singapore
VERY enthusiastic +1, please!!!
dbd123 is offline
post #88 of 344 (permalink) Old 05-22-2010, 11:59 PM
MDKramer's Avatar
http://www.rusteco.com
Mike Kramer
Denis Waitley
MDKramer is offline
post #89 of 344 (permalink) Old 05-23-2010, 01:14 AM Thread Starter
copper204's Avatar
Model: GL1200A
Ok here is Hal's hookey redneck engineering at its best...
The soda blaster carb.. aka aluminum cleaner..
and
post #90 of 344 (permalink) Old 05-23-2010, 01:18 AM Thread Starter
copper204's Avatar
Model: GL1200A
You will need the three folowing commonly available garage items.
1. High flow air blaster nozzzle.
2. 24 inches of 5/16 clear hose.. Clear so you can see when it plugs up.. It will but to clear you just put finger over outlet and lightly pull trigger.
3, Electrical tape. to tape up where u insert blaster
and
Bringing an 84 Aspencade back to life after 20 years Fusionenterprise Goldwing Technical Forum 17 05-15-2015 07:39 PM
Bringing an 83 GL1100A back to life, Sure can use some help Sd455 Goldwing Technical Forum 13 10-29-2011 07:08 PM
Bringing a GL1100 back from the dead john_51 Goldwing Technical Forum 6 04-04-2010 09:20 AM
Bringing back faded paint? flashya2 General Motorcycle Discussion Forum 8 11-09-2008 11:43 AM
Bringing a LTD Back to Life RedWinger Goldwing Technical Forum 29 02-27-2007 07:04 PM
