Neon coil alternative for GL1000, 1100 & 1200 - Page 20 - Steve Saunders Goldwing Forums
 7Likes
post #191 of 191 (permalink) Old 06-13-2018, 02:42 PM Thread Starter
I can now say with certainty a neon coil will work on a 1000. Got my 76 running but no fire to #3, sparks were jumping at the coils. I tried a set of 1100 coils, which work but there is not enough room for them. I checked the amp draw on bot the stock coils and the 80-81 1100 coils, both about 5 amps at idle, the neon coils draw considerably more. I added a ballast resistor from the 1100 coils, 1.5 ohms to the neon coil, in series in the black/white wire and now they draw about 4 amps. Checked spark with my spark tester on the 1100 coils, set at 20K there is a weak spark, on the neon coils at the same setting you can hear the spark, snap. I did have to cut about 2" off the intake horn to make room and built a bracket for the coil. I had already added a relay for the ignition and just use the kill switch to trigger the relay. I do intend to open up the plug gap since there is now plenty of spark.
LarryC and bobalou like this.
Neon coil issue Rokon Goldwing Technical Forum 6 09-24-2015 11:13 PM
GL1100 running funny after Neon coil swap - still runs funny after swap back ntomsheck Goldwing Technical Forum 8 09-18-2015 08:19 PM
GL1100 coil and GL1200 coil teacher Goldwing Technical Forum 11 12-23-2006 11:02 AM
Neon Lights Van Goldwing Technical Forum 1 10-29-2006 06:33 PM
Music to Neon Interface jukeboxjury123 Goldwing Technical Forum 3 03-10-2005 03:27 PM
