GL1500 fuel pump replacement with - Napa P72190 pump is easy fix - Page 5 - Steve Saunders Goldwing Forums
 10Likes
post #41 of 65 (permalink) Old 05-08-2014, 03:11 PM
VLADRRR's Avatar
Year: 1996 + Friendsip 3/1989
Model: 1500
Thank you. One more happy Winger...
VLADRRR is offline
post #42 of 65 (permalink) Old 05-13-2014, 11:50 AM
ghostvet's Avatar
Originally Posted by ttiger View Post
I did some research and found that the Napa P72190 fuel pump ($60) runs at 15 GPH and about 2.5-3.5 psi which is closer to the stock 10 GPH. The Delphi and Airtex pumps listed in other posts are running at +/- 20 GPH.
So, not being an engineer or mechanic, what do these numbers mean? In other words, which is better to have, and why? To me, if the rate is too low, I am guessing the engine will starve for fuel. But does it work in reverse- will the 20gph waste fuel or reduce gas mileage? Would it be better to have the pump at 20gph or even higher? What is the explanation?
Same questioning about the psi- what would be ideally perfect and why?
Thanx,
...the idiot.
Stay safe.
First ride- various minibikes in the 70\'s
First bike- 1974 Suzuki GT380 (bought around 1979)
First big bike- 1981 Kawasaki KZ1300 full dress (bought new)
First Goldwing- 1982 GL1100A (bought 2012)
Another 1982 Goldwing (parts bike)
My newest bike- 1997 Goldwing GL-1500SE (bought 2012)
Oh, and I love Krav maga too! But if Krav Maga is not effective, I highly recommend firearms!
ghostvet is offline
post #43 of 65 (permalink) Old 05-13-2014, 04:04 PM
The extra flow would not hurt the carbs UNLESS as a result the PSI causes damage to the carb parts.
About 3.5 psi is normal, up to 5 psi works fine.
I have read where someone put on a pump that was up to 15ish psi? and it seems to be okay.
3.5 psi will supply more fuel than the engine can burn.
not2old2wing likes this.
post #44 of 65 (permalink) Old 06-09-2014, 10:22 AM
Year: 1996
No longer comes with wires.
Looks great!
One of the cool things about the Napa pump is the power wires that come with it are the exact length for the Wing. I just removed the screw holding the OE wire and replaced it with the wire that came with the pump. No cutting or splicing required. I did wrap them in the same plastic spiral that was on the OE wire.
cbrown3146 is offline
post #45 of 65 (permalink) Old 06-09-2014, 11:48 AM
Year: 1996
Nobody has mentioned what type of fuel line is being used. According to NAPA their saying we cannot use a standard fuel line submersed in gas as it will corrode the outside of the line. Thoughts?
post #46 of 65 (permalink) Old 06-11-2014, 02:14 AM
I purchased "fuel line" at NAPA. It was labeled as 'fuel' hose right on the side of it.
If the word "fuel" is not on the rubber hose, IMO, it is not safe to use for fuel.
post #47 of 65 (permalink) Old 06-11-2014, 10:25 AM
Year: 1996
Pulled the pump. Good bad, right wrong, the OEM fuel hose looked like new so i used it. It was a perfect fit with the NAPA pump. Used the old gasket and no leaks. Could not have gone better. Thanks for all the great info.
post #48 of 65 (permalink) Old 07-05-2015, 01:59 PM
Year: 1995
Make: GL1500
Model: Aspencade - 20th Anniversary
Thanks!
tjernagel is offline
post #49 of 65 (permalink) Old 07-12-2015, 07:53 PM
mwe333's Avatar
Year: 1998
Model: 1998 GL1500 SE
Draining gas.
Hi all.
I am needing to change out my fuel pump, however my tank is almost full. Any ideas on how to proceed?
Also, Rockauto.com has the pump (Carter P72190)for $37.79 plus shipping. I'm buying two. The strainer is$4.62.
Thanks.
mwe333 is offline
post #50 of 65 (permalink) Old 07-12-2015, 09:57 PM
With it almost full, you are most likely going to have fuel all over the floor if you open the fuel pump seal on the tank.
I would place a piece of rubber hose on the pump outlet, let it fall into a gas can, apply 12V directly to the B+ terminal and IF the pump will run at all, it can pump the gas out.
once it starts, it might even siphon the rest of it out.
3 gallons of fuel is about 3 inches below the tank opening IIRC.
failing all of that don't work, roll the bike out into loose dirt.
Open the fuel tank opening and just let the gas run over the top.
stick a hose in the tank and siphon out the rest into the gas can.
LTD, SEi. How to fix fuel pump and where to buy one for $20 newbiker Goldwing Technical Forum 27 04-15-2012 08:14 PM
GL1500 fuel pump replacement tlbranth Goldwing Technical Forum 8 11-01-2011 10:40 PM
1982 1100 Accelertor pump leaking what is an easy fix? ryster Goldwing Technical Forum 3 02-01-2011 05:13 AM
1500 dies fuel pump fix after market anythingoutside Goldwing Technical Forum 5 11-23-2008 05:58 AM
GL1500 Fuel Pump Replacement NeedleNick Goldwing Technical Forum 1 08-02-2008 05:22 PM
