GL1500 fuel pump replacement with - Napa P72190 pump is easy fix - Page 7 - Steve Saunders Goldwing Forums
 10Likes
post #61 of 65 (permalink) Old 06-10-2017, 08:12 AM
Year: 1995
Model: GL1500A
I still haven't adjusted the float, but I've run 3 tanks of gas, and almost 600 miles with no "hic-ups". This is VERY promising! Hoping to get a few hundred more this weekend, too bad I have work too!
AZgl1800 likes this.
jbaviera is offline
post #62 of 65 (permalink) Old 08-10-2017, 10:46 PM
Year: 1995
Model: GL1500A
Well, after 3000 miles, I started having what I think to be the same issue. I replaced the fuel pump (limited lifetime warranty) from O'Reilly's. Now I'm wondering if the problem might actually be a vacuum leak somewhere, and partially shutting off the petcock. When I rebuilt it, I replaced that piece of vacuum tube. Any suggestions?
Also as an FYI, I edited an image of the fuel pump to show terminals of the E16061 ImportDirect pump.
jbaviera is offline
post #63 of 65 (permalink) Old 08-14-2017, 06:19 PM
Pure Texas's Avatar
Make: Goldwing
Some of the replacement diaphrams have failed soon after replacement.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is online now
post #64 of 65 (permalink) Old 09-14-2017, 10:42 AM
TTiger, is the S shaped hose not needed anymore after this conversion?? I can't tell what you did with it???
Please help!!??
JC
joeycline is offline
post #65 of 65 (permalink) Old 09-16-2017, 07:15 PM
when I did that conversion, I used a very short hose to a 1/8" pipe nipple, a right angle adapter, 1/8" nipple and enough hose to reach the fuel outlet port.
others used a longer piece of hose to let it loop around and up to the outlet port...
just make sure it don't kink as that stops all fuel flow, and will burn up that brand new pump.
don't even ask me how I know this.....
See you in Galena, I am here, where are you?
Are we there yet???
NASR 12 in Galena, IL
LTD, SEi. How to fix fuel pump and where to buy one for $20 newbiker Goldwing Technical Forum 27 04-15-2012 08:14 PM
GL1500 fuel pump replacement tlbranth Goldwing Technical Forum 8 11-01-2011 10:40 PM
1982 1100 Accelertor pump leaking what is an easy fix? ryster Goldwing Technical Forum 3 02-01-2011 05:13 AM
1500 dies fuel pump fix after market anythingoutside Goldwing Technical Forum 5 11-23-2008 05:58 AM
GL1500 Fuel Pump Replacement NeedleNick Goldwing Technical Forum 1 08-02-2008 05:22 PM
