Plastic Carb Button Repair - Page 3 - Steve Saunders Goldwing Forums
post #21 of 27 (permalink) Old 05-08-2014, 11:17 AM Thread Starter
Bronko37's Avatar
Model: 1976 GL1000
Final Product
Ok, here is the final product. I liked the aluminum but was concerned about the CV slide hitting the aluminum. Would probably be ok, but was just concerned about how it would perform over the years. I was able to secure some black delron of the correct size, didnt have a larger diameter before so I used the aluminum to get me by. I think this fix is going to both look great and perform great for many years. Also, I have been testing to see how warm these caps get under running conditions. There is literally no heat transfer from the engine to these caps so I think the .0015" press fit with the Krazy glue is gonna hold no problem.
I hope you like these Mike (OnAWingAndAPrayer), thats how your set is gonna look. We already started buffing yours and I have removed the old busted buttons.
I am going to install this cap on my bike and run it for awhile to see how it performs with the custom button. I am still dialing in my ignition and timing systems so it may be a little while before I am able to run this for a lot of miles. I will keep you posted. In the meantime, let me know what you think!
If you go fast enough your never in one spot long enough to get hurt
Bronko37 is offline
post #22 of 27 (permalink) Old 05-08-2014, 08:24 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
It looks Great ! The black will distinguish them from factory , so that I think is nice . I did get your message/photo earlier today . Those caps were a little more than barn find grungy . I didnt expect you to clean them . I figured I would be buffing them later . So a big thanks for spiffing them up ! Put some miles on them as you wish . My 75 is not ready to use them at this time .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #23 of 27 (permalink) Old 05-12-2014, 02:45 PM Thread Starter
Bronko37's Avatar
Model: 1976 GL1000
Originally Posted by 77Pinto View Post
Nice work.
Off and on for a few years I have been thinking of a way to fix these, but in a way that would accomplish two things: 1) Be a way so that someone could buy a kit and do it themselves at home with tools they might already have (like Randakk's great float pin kit). 2) Appear to be factory original, at least with a normal glance.
Bill
That would be great, unfortunately given the parts design I just don't see any way possible for anybody to do a proper repair job on these without specialized machine tools and knowledge of the OEM part design. The average joe will have to stick with the JB weld technique. That is unless I can get my design dialed in and properly tested. Once I am confident about this design performinance and longevity I may try to help people repair thiers as a service.
Bronko37 is offline
post #24 of 27 (permalink) Old 05-13-2014, 02:25 PM Thread Starter
Bronko37's Avatar
Model: 1976 GL1000
WingandAPrayer
Mike,
Here are your finished caps. I installed my repaired cap on the 76 and was able to run it. I tried out the sync gage. It works pretty well. I still need to get a new set of points and set my timing all up. When I do that I will re sync the carbs.
I am pretty confident about my repair now that I have been able to do several. I would be happy to work on that set from your running bike if you want me to.
Bronko37 is offline
post #25 of 27 (permalink) Old 05-13-2014, 08:38 PM
IT's amazing how youv'e turned those old broken caps into nice looking ,usable, repaired caps. Those are SWEEEET. You have me wanting to work on the 75 again(as if I have time ) I am busy getting ready for NASSIR 7 . I better see if I have the title /paper work and get that squared away .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
post #26 of 27 (permalink) Old 07-08-2014, 11:24 AM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
http://ngwclub.com/forum/viewtopic.php?f=55&t=53602
CWN is offline
post #27 of 27 (permalink) Old 07-22-2014, 10:11 PM Thread Starter
Bronko37's Avatar
Model: 1976 GL1000
Mine are still cooler
Bronko37 is offline
abs plastic repair... UbarW General Motorcycle Discussion Forum 10 03-06-2013 08:26 PM
Plastic Repair Jsalpha2 Goldwing Technical Forum 9 10-11-2011 12:08 AM
ABS plastic repair wingd Goldwing Technical Forum 8 09-14-2010 08:00 AM
plastic repair woodbutcher Goldwing Technical Forum 4 02-14-2008 12:30 AM
Solution to plastic repair GL1200 and others Wildcat Goldwing Technical Forum 13 06-20-2006 04:30 AM
