Ok!!! Darkside tell your side!!!! - Page 33 - Steve Saunders Goldwing Forums
 23Likes
post #321 of 367 (permalink) Old 01-09-2017, 12:20 PM
Originally Posted by S4rhoolie View Post
This inquiry is/was for GL1500....guys with 1800 have done it, i'm aware...thx
Oops, I did not look at your profile.
That is why each thread that is started should EXPLICITLY STATE what model bike the inquiry is about.
So, for the 1500 there are a few choices available.
The taxi tire is most popular, but a couple of others are out there.
post #322 of 367 (permalink) Old 06-17-2017, 11:10 AM
Quick Cal's Avatar
Model: 84 1200 Interstate
1200 Darkside tire
So have you guys came up with a good choice for a 1200 tire?
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
84 GL1200 Interstate
Quick Cal is offline
post #323 of 367 (permalink) Old 06-18-2017, 10:09 AM
C Trooper's Avatar
Model: '84 Interstate / '87 Interstate
1200 Darksider
Well for my 2 cents... I am currently riding 2 1200 Wings with CT... my 84 has over 6000 miles on it and my 87 almost 2000.... I am not a risk taker when it comes to my riding style... I ride to go from point A to point B comfortably, and safely... I ride on concrete, asphalt, gravel and grass... The tires in question are a BF Goodrich and a Nexen... what I can say without question is the BF Goodrich does work... BUT, because of the squared shoulder tread profile, the 84 wing will tend to travel in a straight line even during a turn...So this tire will be replaced with another style tire soon... my 87 wing running on the Nexen is really nice to ride... the rounded shoulder profile feels and handles more like a cycle tire... when I ride on gravel or grass there is much less bounce in the rear and more stability in heavy gravel... my wife enjoys less bumps and a smoother ride, this equals more ride time for us...
If you have any questions, I'll be happy to answer
Throttle up !!!!
C Trooper
Bike in storage \'78 Honda CB 750 K
Past
Yamaha 125
Kawasaki 440
Knowledge is Power- Hobbes
C Trooper is offline
post #324 of 367 (permalink) Old 06-18-2017, 10:52 AM
Quick Cal's Avatar
Throttle up !!!!
C Trooper
Thanks for the reply.
What Nexen tire did you go with. Any issues mounting it.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #325 of 367 (permalink) Old 06-18-2017, 11:03 AM
BrianInPA's Avatar
I have a Classic 165/80R 15 on my 1100 that has a 1200 Swingarm, the wheel/tire was also on my 84 Standard.
I am currently just shy of 12,000 miles on the tire and I am no where near the wear bars of the tire. This tire has rounded edges when it is inflated so it makes cornering real easy. The down side to mount a car tire on a 1200 wheel is seating the bead. Either inflate the tire with over 80 PSI of air and risk blowing out the tire or machine the wheel to remove the ridge that is cast into the rim.
Brian
BrianInPA is offline
post #326 of 367 (permalink) Old 06-18-2017, 12:59 PM
C Trooper's Avatar
Darksider
QuickCal,
I can't remember the specific Nexen tire I had mounted... I am not near the bike at the moment so I can't look.... I do remember that it was not an expensive tire (about $76) and there was no issues having the tire mounted at my local Firestone shop... I would recommend to the tire people to use the most "slippery" tire grease they have to mount the tire...
Throttle up !!!!
C Trooper
Past
Yamaha 125
Kawasaki 440
post #327 of 367 (permalink) Old 06-18-2017, 04:36 PM
Quick Cal's Avatar
QuickCal,
Throttle up !!!!
C Trooper
It's probably the same size that Brian used. A 165/80R 15. but please verify when you can.
Has anyone found a run flat version in that size?
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #328 of 367 (permalink) Old 06-18-2017, 04:45 PM
BrianInPA's Avatar
Not likely. There aren't many options in that size.
Brian
post #329 of 367 (permalink) Old 06-19-2017, 05:21 PM
Quick Cal's Avatar
So I'm about to pull the trigger on a Nexen 165/80r/15 for my 1200.
Just wondering what balancing method you guys are using for a ct. I've been using counteract beads in my Shinkos. I have IIRC a 2oz pack that is enough for my Shinko rear.
You guys think that would be ok in this Nexen?
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #330 of 367 (permalink) Old 06-19-2017, 05:49 PM
any brand bead should work fine,
I am using Dyna Beads and they have never clumped up while I was using them, in 3 different bikes.
Darkside fatwing chris General Motorcycle Discussion Forum 51 05-12-2014 05:27 PM
Going DarkSide or Not KC9KAS General Motorcycle Discussion Forum 67 06-01-2012 11:33 AM
The Darkside for me. odies Goldwing Technical Forum 99 04-27-2012 10:30 PM
Darkside legends Goldwing Technical Forum 19 12-31-2011 02:27 AM
I went to the Darkside norton General Motorcycle Discussion Forum 23 05-29-2010 06:24 AM
