Won't start....... Ahhhh....... GL1500, it is fixed now. Bad Transistor in ECU - Steve Saunders Goldwing Forums
 3Likes
post #1 of 46 (permalink) Old 07-01-2015, 05:12 AM Thread Starter
chris301up's Avatar
Make: Honda Goldwing
Model: 1500 SEV
I removed the air cleaner assembly from my GW 1500 SE and, although it started briefly whilst removed, it cut out and now won't restart.
Plenty of fuel in tank and battery fully charged but won't have it.
It seems as though fuel is not getting to carbs. Have removed fuel lines and sucked through and they seam fine?
Am I missing something??
chris301up is offline
post #2 of 46 (permalink) Old 07-01-2015, 06:11 AM
Did you disconnect the air temp sensor?
post #3 of 46 (permalink) Old 07-01-2015, 09:19 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
If I'm correct that's the 2 pin green connector? - Then yes!
post #4 of 46 (permalink) Old 07-01-2015, 09:33 AM
Not sure if that would cause it to not start but plug it in and try it.
post #5 of 46 (permalink) Old 07-01-2015, 11:06 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Right. Have removed and reassembled the air cleaner unit, checked all connections are good, but it wouldn't start.
Decided to try running a jumper wire from the positive terminal of the battery to the fuel pump and it started. It will continue to run when removing the jumper wire, but when I try to accelerate, it hesitates and cuts out again. The only way to restart it is to use the jumper wire again.
Weird !!!
post #6 of 46 (permalink) Old 07-01-2015, 11:38 AM
Year: 94
Model: 1500 SE
isn't there a vac system /ck valve or something that has an issue? I recall mention of testing one, but not sure about operation (I'm new)
Fuel Gurus?
Aloha Tom is offline
post #7 of 46 (permalink) Old 07-01-2015, 12:04 PM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Fuel Gurus?
If you're referring to the Petcock Assembly, I bypassed that first and it didn't make any difference.
I have had it running with it bypassed, and fitted 'in line' with the same results.
Just found this underneath the bike. Does anyone know what it is, what is does and where it goes? Must have come off when removing air cleaner assembly earlier?
post #8 of 46 (permalink) Old 07-01-2015, 01:24 PM
Chromo's Avatar
Weird !!!
If I am reading that correctly it's not weird at all, makes sense.
If the fuel pump only runs when you jumper it, then you have some type electrical problem of course that the bike is not powering the fuel pump like it should. Check fuses and any/all wires and connectors where you been working. Something may be loose or unplugged.
Since it does run when pump has been jumper-ed, that pretty much eliminates anything else other than electrical to make the pump run as it should.
I think you are saying the pump only runs when jumped and bike still runs after removing the jumper? This would be normal I think for a short time.
When you run the pump you fill the carb bowls, the bike will run for awhile without a fuel pump just on the gas that is in the carbs, then of course you run out of gas because the pump is not pumping in more.
If the above is correct in your case then that is why
"when I try to accelerate, it hesitates and cuts out again. The only way to restart it is to use the jumper wire again."
Your out of gas again because the pump is not running.
It's kinda amazing how long a bike can run on just full carb bowls really without a pump working.
When I want to run an engine out of gas it seems to take forever just sitting there idling and revving it sometimes.
With my 1100 when it sits for a long time like months or so 1 o-ring will dry and leak gas for awhile next time I try to run it. I just went through that again after having let it sit near a year now.
Once the O-ring is wet for awhile it stops leaking and all is fine.
SO, wanting to see how the bike ran after sitting the year I turned on the petcock till the bowls are full and 0-ring just starts to leak, then turn off petcock. As the bike tries to run out of gas as the bowls get empty I just turn on the gas again for a minute to refill the bowls.
I can ride a really long ways on just the fuel in the carb bowls! Once I had the O-ring leak slowed to just a bit of dripping I took the 1100 out and rode about 40 miles or so. I turn on the fuel to fill carb bowls a minute or less then turn back off, I ride a long ways before the 1100 starts to act low on fuel then I just turn on fuel till she smooths out again then turn fuel back off again. A nice thing about having a manual petcock I can reach easy.
I mention that because you can do the same thing with the jumper wire to the fuel pump. Connect it to run pump and fill the carb bowls then remove it. When bike starts to sputter, or hesitates when opening the throttle connect the jumper wire again. I'd not ride that way of course, but for testing purposes you should be able to keep the bike running as long as you want that way.
That would verify the only problem is bike does not power the fuel pump when running like it should after started.
As for the leaky O-ring on my 1100 I mentioned, it don't leak a drop now!
I just had to get it wet and warmed up to riding temps for awhile.
Chromo
I ride for FOOD
82 1100 riding sometimes, Red
Chromo is offline
post #9 of 46 (permalink) Old 07-01-2015, 03:39 PM
The fuel pump gets power directly from the ECU so no fuse or relay involved that would not also keep the engine from running. Check for power on the blk/blu wire in and out of the inline capacitor on top of the tank.
post #10 of 46 (permalink) Old 07-02-2015, 04:24 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
I have run some basic checks and can confirm there isn't any power (either when running or on start up) at the BLK/BLU wire to fuel pump. Also, there isn't an in-line capacitor fitted to my machine as far as I can see.
Seems to be a common problem with these machines?
Could the ECU be toast ?
GL1500 won't start chiefcherokee Goldwing Technical Forum 30 10-07-2012 01:00 PM
GL1500 won't start , ECU+heat = no spark? rampas Goldwing Technical Forum 82 06-03-2012 06:38 AM
GL1500 won't start markabbott11 Goldwing Technical Forum 3 11-29-2009 06:37 PM
