GL1500 LED Tail/Brake Light Conversion Cancels Cruise Control Problem Solved - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 14 (permalink) Old 03-14-2016, 12:32 AM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
Originally Posted by Aloha Tom View Post
Question on back-off modulator, DO I have to use one specific- maybe has connectors for the Wing? as found at wingstuff or similar
OR can I grab the one currently on the Shadow that was wired in and re-use it.
Would like to have it just on the spoilers LED strip, 94-SE
those extra bright LED bulbs Indiana posted pics of look like the right idea,,,
lots of running light and more brake lights.
I don't see why you couldn't use it on the spoiler, as long as it is LED compatible. However, you have to be sure and wire it in the correct place, as the spoiler on my 97 serves double duty as running lights and brake lights. Honda has a special circuit to accomplish this, and you'd need to wire it in after that circuit, to the brake light function only. I did something similar and had to use a relay to accomplish it. It's been a while, and I forget the exact wiring.
Thomas Paine December, 1776
Bluewaterhooker0 is offline
post #12 of 14 (permalink) Old 03-14-2016, 10:31 AM
Year: 94
Model: 1500 SE
thanks I will look into it some more,,,may be worth getting a unit ready made to plug and play for the Wing
Is such a unit available--group knowledge??
Aloha Tom is offline
post #13 of 14 (permalink) Old 07-03-2017, 10:22 PM
Model: GL1500A
LED solution
I put LED stop/ tail light bulbs in my '97 GL1500 and had the problem of the turn signals canceling the cruise, it worked ok with one standard bulb installed.
The turn signal circuit is not connected to the stop/ tail light circuit right?
Wrong, when i took the 5 wire to 4 wire converter out and rewired my trailer to separate turn signals the problem went away.
Now i can run all LEDs, the feedback was coming from the 5 to 4 converter.
retread is offline
post #14 of 14 (permalink) Old 07-04-2017, 12:02 AM Thread Starter
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Good catch.
However I want to remind you one point that if a 1157 led bulb and a regular 1157 bulb are used on the same circuit, and there is not a diode protection in the LED bulb, voltage will leak into the regular bulb and find the ground through its filament. This will toast the resistor in the LED bulb sooner or later based on the usage.
Erdeniz Umman is offline
LED Tail light conversion BlackGW General Motorcycle Discussion Forum 13 10-05-2014 10:26 AM
LED for GL1500 Tail and Front Conversion JoeS For Sale/Wanted Forum 0 08-07-2013 07:09 AM
Cruise control problem solved, GL1500 NevadaDave Goldwing Technical Forum 6 10-03-2012 08:02 PM
GL 1500 Cruise Control Problem Solved jacksrwild Goldwing Technical Forum 4 08-29-2012 06:47 PM
GL 1200 Factory Cruise Control Problem SOLVED! NDAV8R Goldwing Technical Forum 1 06-24-2006 08:58 AM
