GL1500 Gear Indicator - Page 5 - Steve Saunders Goldwing Forums
 31Likes
post #41 of 56 (permalink) Old 06-06-2017, 01:43 PM Thread Starter
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Originally Posted by jbaviera View Post
Thanks for that info. Thinking about putting a volt meter in that spot, since I need to replace some dash lights anyway. Now, if I can disassemble the dash without destroying it, I was thinking of putting this in the OD spot. I have to admit though, I like the concept of this display (https://www.youtube.com/watch?v=ENXz6fsfI08) and it's features, however, I would be happy of the just gear indicator could just be added to the current display.
That LCD unit is developed by a German guy, and it may be good replacement for the broken OEM units which are hard to find and very expensive.
It will fit all GL1500s (some models do not have 2nd gear signal as you know) because it does not use any gear signals, instead it uses speedometer and rpm signals to calculate the gear.
However, one feature that I don't like about it is, it will not show any number while stopping. So you will have to find N first and then put the gear in 1 etc.
On my solution, you will see the gear in any case, and since I have used the voltage of the ECU input, it is very useful to understand the kill switch position (I am sure many of us tried to start the bike when the kill switch is off).
Erdeniz Umman is online now
post #42 of 56 (permalink) Old 06-06-2017, 02:35 PM
Year: 1995
Model: GL1500A
I didn't know the particulars behind his display, but I like the general concept. Yours I think I can do, though I've never etched my own circuit board. Shouldn't be too hard to buy a kit for that.
jbaviera is offline
post #43 of 56 (permalink) Old 06-06-2017, 03:01 PM
paradisetexassty's Avatar
where can you buy this unit?
Sent from my SM-G530T using Tapatalk
paradisetexassty is offline
post #44 of 56 (permalink) Old 06-06-2017, 03:32 PM Thread Starter
In his YouTube video he says it will be ready for sale this summer.
post #45 of 56 (permalink) Old 06-06-2017, 03:47 PM
ok thanks
post #46 of 56 (permalink) Old 06-13-2017, 06:46 PM
Rudolph's Avatar
Year: 1975
Model: GL 1000 K1
This is a --$12.50-- P&P gear indicator solution for my 1975 GL1000 K1 ...............
Tiny magnet (shiny silver) attached to the back of the gearshift pedal.....
Up-shift sensor with electr. wire (black plastic element) mounted on electr. starter with tiewrap..
Down-shift sensor with electr. wire (black plastic element) mounted on the lower frame tube....sensor with small tiewrap on open plastic clamp....sensor + clamp positioned on tube.....
Exact positioning of the sensors versus the magnet to achieve proper shift indication is a tough job......
Proud winner of the NGWClub-USA contest Bike of the Year 2016 GL1000 K1 1975
Rudolph is offline
post #47 of 56 (permalink) Old 06-13-2017, 08:18 PM
Year: 1995
Model: GL1500A
Interesting, but I hear it can display more gears than you have.
You DO have a beautiful bike though.
jbaviera is offline
post #48 of 56 (permalink) Old 06-13-2017, 09:18 PM
Rudolph's Avatar
Year: 1975
Model: GL 1000 K1
Thank you for your compliment.
I am the 2nd owner since 1978.......
From 1983 it has been stored in my garage for an uninterrupted/untouched period of 31 years.
It only had/has 11.000 mls on the odo....
Due to a good preparation in the past it "survived" relatively "unharmed", the engine could be turned over etc. however the carbs, brakes etc. needed full inspection and revision.......everything had to be inspected and repainted.
From 2014 to 2015 I dis-/assembled it completely (excl. engine and gearbox) and "restored" it; the Candy Blue Green / PB-2 C-S paint is still the original one.
It took me that year 800 labour hrs plus 400 hrs on the internet for information, knowledge, data, spec's, parts purchase etc. etc.
Here I started with the cpl. disassembling.........
Ref. the indicator:
Indeed it can display up till 8 gears, but when mounted on the GL1000 and with true/proper up- and down-shifting the indication will be limited to the 5 gears of the Honda.......
CrystalPistol likes this.
Rudolph is offline
post #49 of 56 (permalink) Old 06-13-2017, 09:40 PM
Year: 1995
Model: GL1500A
You're welcome.
That might be part of my problem, I sometimes feel that I haven't hit the "high" gear, and I can see it now, I'm in the non-existent "6th" gear. Unlike probably most (if not all) riders here, I didn't get my first bike till I turned 50, and I've only been riding the past 8 years, whereas everyone else has probably been riding since their early 20's (or longer).
jbaviera is offline
post #50 of 56 (permalink) Old 03-11-2018, 05:20 PM
gipsy42's Avatar
Model: '93 GL1500 SE "Blue Angel"
Send a message via Skype™ to gipsy42
I need HELP, Please!
I have also prepared a digital gear indicator, for whom are interested in.
Although I have tested the circuit on pc program you may need to change the capacitor and zener diode on your real circuit.
Red line you see on the diagram will be on the top surface of the pcb, you may simply use two wires to connect those pins.
Circuit includes the control unit that produces 1st gear signal, U1 encodes the gear input signals and U2 decodes them and sends to display.
Hi Erdeniz, indeed your design is great but I need your help, for I built the indicator but can't make it work.
My knowledge of electronics limits me to follow some circuits, can't analyze digital signals.
To begin I must say it's my first time making my own Pcb, used the hotiron method, and the very first one was mirrored, I realize that after have soldered all parts and T1 looked backwards, anyway it served me for the purpose of adjust the signal for 1st gear; the lowest zener value available here is of 2.4 V. and in conjunction of a 330 mf capacitor I'm getting about 2 seconds delay which suit me.
For a bench test I set up a series of 7 diodes resembling the 7 segment, ( which is already fixed in the bike and not available) and hooked everything in a moke up ( picture attached)
To test I have an analog and a digital VOM;
My measures say that even when both IC are connected in parallel there is no power at pin 16; and 5V at pins 9 thru 13.
By grounding the leads simulating the gear switch sender I can see the first part of the circuit works Ok.
In the picture showing the Pcb, could it be that a connection is missing between U2 pin 16 and +B??
Thank you in advance, I'll really appreciate if you can lead me to complete this job.
Mario
Mario
And still riding...
I just regrets the things I haven't done.
gipsy42 is offline
Gear Indicator for GL1500 Bluewaterhooker0 Goldwing Technical Forum 12 11-18-2014 09:39 AM
Gear position Indicator GL1500 Haroldmac Goldwing Technical Forum 2 07-11-2012 06:25 PM
GL1500 Gear shift indicator JimArmstrong1 Goldwing Technical Forum 8 06-08-2012 08:14 AM
Gear indicator for GL1500? sunsetnkc Goldwing Technical Forum 10 05-06-2010 10:47 AM
GIPRO DS-H02 GEAR INDICATOR - Gear Indicator 99winger General Motorcycle Discussion Forum 3 04-03-2010 09:40 AM
