2004 1800 Honda Goldwing anti-dive forks - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 09-21-2015, 07:24 PM Thread Starter
Year: 2004
Make: Honda Gold Wing
Model: GL 1800
Send a message via AIM to jackyson
I have heard a lot about the anti-dive plunger not working properly on the 1800 Wings, so since I had the front fork apart to replace the fork seal I thought I should check it out at the same time.
Funny there is nothing in the service manual about checking it or servicing it. When I took it apart the plunger part that stops the fork oil from flowing was stuck in the closed position. This is more than likely what caused the seal to blow out. They are quite easy to disassemble and clean out, it seems to work fine now, time will tell. The one caution I would recommend is that since you are working with a part that contains both fork oil and brake fluid, be careful not to let the two fluids mix. It will destroy the O rings inside.
You have to either remove the fork from the bike or be prepared to refill it while installed. This can easily be done by jacking the bike enough to keep the front wheel off the ground while removing the fork cap.
jackyson is offline
post #2 of 9 (permalink) Old 09-21-2015, 10:19 PM
The brake fluid is only in the servo on top, no reason to open it to chance getting brake fluid in the forks.
post #3 of 9 (permalink) Old 09-22-2015, 05:48 AM
De Motormuis's Avatar
Year: 1995
Make: Honda Goldwing
Model: GL 1500 SE
Hallo jackyson
Welcome on this nice forum. Wish you al the best.
And good luck with your Wing.
__________________
Greetings Wil.
It is beautiful on the road with all the Goldwings.
A Goldwing rider is a happy rider.
See my Albums to see what my nickname means, and see photo's from our holiday in Australia.
Also see my other albums from my motor holidays.
Look in My Garage for photo's from my Goldwing
GL 1500 SE. Two tone green.
De Motormuis is offline
post #4 of 9 (permalink) Old 09-22-2015, 06:05 AM
mowerdoc's Avatar
welcome to the forum
mowerdoc is offline
post #5 of 9 (permalink) Old 09-22-2015, 07:29 AM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
Dumb question, I'm sure. but, as mentioned, the brake fluid is on the upper part of the ADV, which is on the outside of the left fork slider. How could this get into the fork or mix with the fork oil??????????????
tfdeputydawg is offline
post #6 of 9 (permalink) Old 09-22-2015, 05:55 PM
Year: 2001
Model: GL1800A
Hello & Welcome to the forum family from Pennsylvania. Good luck with your Wing!
Darkside # 1711
Jstkraze is offline
post #7 of 9 (permalink) Old 09-24-2015, 04:45 PM
lionelgo50's Avatar
Welcome from Oklahoma Enjoy the wing
Dave
Ride Safe and Ride Often, Keep the Shiny Side up and Many Happy Miles and Smiles.
In God We Trust; All Others Must pay Cash!!!
Current Goldwing 2016 Gl1800 Matte Silver
Other Rides
2007 Honda 110cc
Past Rides
2 1985 Goldwing Aspencades, 2006 Harley Davidson Sportster 1200, 2006 Goldwing Navi, 2007 Honda Rebel, 1994 1500cc Goldwing Interstate, 2010 Gl1800 Trike, 1997 GL1500 SE, 2012 Harley Davidson Heritage Softail
lionelgo50 is offline
post #8 of 9 (permalink) Old 09-25-2015, 07:28 AM
Crazy Dog's Avatar
Warm welcome to you buddy
Be strong at all times
Crazy Dog is offline
post #9 of 9 (permalink) Old 09-26-2015, 09:06 AM
Rocketman911's Avatar
Year: 183 BC
Make: Not telling how much money I make!
Model: I don't have a model, I ride the real thing!
Suck it up buttercup!
If global warming were true, then why do we have so many snowflakes everywhere!
Rocketman911 is offline
  Steve Saunders Goldwing Forums > Forums > New Members Introduction Forum
honda goldwing 1800 /2004 Darius Trikes, Trailers and Sidecars 1 07-07-2015 01:22 AM
GL1800 Anti Dive Unit (Brake servo-pressure sensing anti dive) Paul Hopewell Feedback for Hondas Goldwing Team 3 10-10-2011 02:05 AM
how much fork oil do you put in a honda TRAC anti dive forks ? moonshiner General Motorcycle Discussion Forum 5 02-22-2011 02:54 PM
Anti Dive Forks GL1500 Wingboomer Goldwing Technical Forum 6 06-13-2010 09:43 PM
Anti dive forks 83 aspencade walter mitty Goldwing Technical Forum 2 06-28-2009 11:55 AM
