86 GL1200 SEI Engine Idle Speed trouble - Page 2 - Steve Saunders Goldwing Forums
post #11 of 19 (permalink) Old 01-05-2019, 06:24 PM
These are not sophisticated enough to have automatic idle control. Try adjusting the throttle stop screw, not the synch screw. The throttle stop is above and behind the synch screw which is on the right side throttle shaft. The throttles may also need to be synchronized but try the stop screw first.
post #12 of 19 (permalink) Old 01-05-2019, 08:07 PM
Rednaxs60's Avatar
There are three adjustments on the throttle linkage. The idle adjustment screw is in the middle of the throttle linkage where the left and right throttle linkages join, middle at the rear of the engine. the cylinder bank sync screw is behind the CFI cover on the right side of the engine - if you adjust this screw without having vacuum gauges connected you will throw the cylinder bank balance out, and will have to use vacuum gauges to bring the cylinder banks back into balance. The third adjustment is behind the left CFI cover. It is a small screw that when the engine TPS is calibrated, it is to be backed off and tightened with a locking nut so that the throttle linkage is not impacted.
I have my air chamber out because I had to fix the air filter box securing arrangement and I replaced some IAC and vacuum hoses.
The first picture is of the idle adjustment screw in the middle of the throttle linkages. You can see how the throttle linkages are connected and the idle adjustment screw. The screw pushes against a stationary, non adjustable stop.
The second picture of the cylinder balance screw that you find behind the right side CFI cover, on the right side of the air chamber, shows the cylinder balance screw pushing against the right side throttle linkage. Behind the throttle linkage is a spring pushing against the throttle linkage opposing the force of the screw. There is no other adjustment. This screw is only adjusted when you do a cylinder balance.
The third picture is of the TPS calibrating screw. When not calibrating the TPS the screw is as I mentioned backed off and locked in place with a lock nut. You can see the space between the screw and throttle linkage.
The fourth picture is off the throttle linkage as attached.
Another item to check is the throttle cables. I was having trouble getting the throttle to return to idle without having to manually assist. What was happening was the cable had cut into the internal sheathing and was binding - after 32 years can be expected.
Check cable adjustment and routing as well. The routing of the throttle cables can cause the engine idle to increase if it is not routed properly.
For the IAC system, this is my thread on the Classic forum with pictures of the IAC internals. Replaced the IAC valve for a different reason, didn't fix it but I now have a new IAC valve installed. Here is the thread: https://www.classicgoldwings.com/for...+valve#p206808
Hope this helps. Cheers
Ernest
Rednaxs60 is offline
post #13 of 19 (permalink) Old 01-05-2019, 08:26 PM
Did you find a repair manual?
post #14 of 19 (permalink) Old 01-07-2019, 06:33 PM Thread Starter
Wingrider2012ak's Avatar
Year: 1986
Model: GL1200SEI
Yes rednaxs60 got me a very thorough manual. Thanks for the detailed information on the throttle adjustments and air valve info. I'll work on those adjustments over the next couple evenings.
Wingrider2012ak is offline
post #15 of 19 (permalink) Old 01-09-2019, 09:17 AM
Year: 2010
Make: Honda Goldwing
Model: GL1800-Made in USA
You're never too old....
FredFromArnold is offline
post #16 of 19 (permalink) Old 01-09-2019, 07:12 PM
Magic Moderator
trike lady's Avatar
Hello and welcome to the forum.
Retired trike builder.
trike lady is offline
post #17 of 19 (permalink) Old 01-18-2019, 11:40 PM Thread Starter
Year: 1986
Model: GL1200SEI
Thanks for the help, the engine speed is under control. Not knowing where to look to see the lights on the computer I took the trunk off and pulled the computer out. Ever since unplugging and plugging back in the computer the idle speed dropped from 3200rpm to 2000. Still high but when I pinched the hose feeding out of the air valve idle speed dropped below 1000rpm. I ordered an air valve off eBay and installed it the other day and it works great. So I had a bad connection at the computer and a bad air valve. Now that it runs correctly I just need winter to be over.
post #18 of 19 (permalink) Old 01-19-2019, 12:03 AM
Rednaxs60's Avatar
Love it when a plan comes together. Cheers
Ernest
post #19 of 19 (permalink) Old 01-19-2019, 12:29 AM
Winter? Do they have winter in Alaska?
  Steve Saunders Goldwing Forums > Forums > New Members Introduction Forum
85 Ltd-86 Sei-87 lower corning lights-sei fairing side lights CWN For Sale/Wanted Forum 1 09-21-2014 08:37 AM
85 ltd/86 sei corning lites-sei side marker lites CWN For Sale/Wanted Forum 0 04-22-2013 07:28 PM
86 1200 SEI cruise top set speed motor22 Goldwing Technical Forum 7 09-19-2007 03:15 PM
Slow idle return on '86 1200 SEI TNroadrider Goldwing Technical Forum 4 08-25-2007 07:45 AM
'86 SEi fast idle wildman Goldwing Technical Forum 8 02-02-2006 08:29 PM
