1984 Aspencade electrical drain - Page 3 - Steve Saunders Goldwing Forums
 3Likes
post #21 of 30 (permalink) Old 05-19-2019, 08:51 PM
Originally Posted by rockinroland View Post
Dave, not sure what pulling the voltage regulator will tell me. Is there something else Iím missing like testing it?
If your problem goes away the regulator is bad.
You don't have to know the how and why.
Ken Bergen is online now
post #22 of 30 (permalink) Old 05-19-2019, 09:28 PM
Magic Moderator
trike lady's Avatar
Get a good one the stuff on Ebay seems to not be good especially the made in China junk.
You can find some oem Honda ones from salvage yards: https://www.ebay.com/itm/84-85-86-87...8AAOSwdU1cyINh
Retired trike builder.
trike lady is offline
post #23 of 30 (permalink) Old 05-19-2019, 09:51 PM
It will tell you if that is the problem. The regulator is the only thing that can have power to it at all times if as you said you already tried pulling all the fuses in the fuse box.
post #24 of 30 (permalink) Old 05-19-2019, 10:15 PM
Magic Moderator
trike lady's Avatar
A bad diode inside will cause the problem. The diodes job is to allow current to flow in one direction, its a one way street for electricity. If a diode goes bad the current flows both ways. That starter relay needs to go too.
The arrow show the direction in which the flow travels, the line crossing in front of the arrow is the blocker and nothing should back-flow. By unplugging the regulator/rectifier you'll know where to lay the blame for the drain.
If you view the pic of the regulator you'll see 3 yellow wires, a pair of green and a pair of red and a lone black. The yellow goes to the stator, green is ground and red to battery.
post #25 of 30 (permalink) Old 05-26-2019, 09:12 AM Thread Starter
Year: 1984
Model: Aspencade
Removed the voltage regulator/rectifier and the 14.3 v drain is still present. Any others ideas?
rockinroland is offline
post #26 of 30 (permalink) Old 05-26-2019, 09:44 AM
We need an amp reading, voltage is almost meaningless. Do you get a spark when connecting the battery?
post #27 of 30 (permalink) Old 05-26-2019, 01:04 PM
Unplug the regulator, leave everything alone for a day, if the battery isn't dead when you come back the regulator is the problem.
post #28 of 30 (permalink) Old 05-26-2019, 01:30 PM Thread Starter
Year: 1984
Model: Aspencade
Yes, always get a spark when connecting the negative battery cable.
post #29 of 30 (permalink) Old 05-26-2019, 05:35 PM
Ok then you have to start disconnecting things until the short goes away.
post #30 of 30 (permalink) Old 05-28-2019, 12:38 AM
Dave-85-LTD's Avatar
Year: 1985
Model: GL 1200L Limited Edition
If you have a drain it will be in amps not voltage. The battery fully charged, but not while being charged should be close to a static 13.7 volts.
Connect a multi-meter in the amp function between the battery and the bike, (start on a high amp setting). all power to the bike must run through the meter. Do not try to start while using a amp-meter. this should tell you if there is a constant drain.
Clocks and such may pull a few milliamps, but if your batter is dead in an hour or so, you may have a bad battery or a short.
Charge battery while disconnected from bike, disconnect from charger, wait at least 48 hours, hook up to bike, bike should be able to start just fine. If it does not, the battery may have an internal short. Get a new battery.
Patriot Guard Rider
I ride, and stand, for those who have fallen for us, and in memory of my father ( Army 1944-1947)
Previous bikes
CT 90---125 Benley (Honda)---insane minibike with 125 Honda motor---1982 CB 650
Current bikes
CN 250 Helix----1985 GL1200L Limited Edition
Dave-85-LTD is offline
  Steve Saunders Goldwing Forums > Forums > New Members Introduction Forum
Electrical drain 94' 1500 Cap10Paul Goldwing Technical Forum 3 06-25-2013 02:00 PM
electrical drain v_man_1 Goldwing Technical Forum 4 11-03-2008 01:03 PM
Intermittent electrical drain Newbee1 Goldwing Technical Forum 25 07-18-2008 12:52 AM
Electrical Gremlins - Battery Drain noexit Goldwing Technical Forum 6 08-09-2007 02:56 PM
How to check electrical drain PDKing Goldwing Technical Forum 8 11-12-2005 08:23 AM
