Reverse Not working - Steve Saunders Goldwing Forums
 2Likes
  • 2 Post By BLUTHUNDR31
post #1 of 9 (permalink) Old 09-17-2019, 07:18 PM Thread Starter
Reverse Not working
I have a 1997 Honda Gold Wing Aspencade GL1500. My Turn Signal indicators on the Dash light up when I start the engine. Both lights stay on and when I turn either right or left turn signal, they work fine. The main problem i'm having is when the both turn signal lights are on in the dash. When I pull up my reverse handle and the R lights up on the dash. When I push the start button on the handle bars. The rear wheel on moves about 1" or 2" then nothing. Today after ridding it a little. The turn signal on the dash went out but when i pulled the handle on the frond brake they came on again. When I got back into my driveway, the lights were still on so I pulled the front brake leaver a few times and the turn signal lights on the dash went out. I put the bike reverse handle up and the R came on in the dash. The i pushed the start button and it backed the bike up when ever I pushed the button. Later on after I took another ride the lights stayed off on the dash but when I got back home. The same thing again the turn signal lights on the dash was on and could not get them to go off even after pull the front and back brake leavers..
Would like to know if anyone out their has a similar problem that might be able to help me.
Robert Pryor is offline
post #2 of 9 (permalink) Old 09-17-2019, 08:32 PM
Please fill in your profile.
Thank you.
post #3 of 9 (permalink) Old 09-17-2019, 08:40 PM
Magic Moderator
trike lady's Avatar
Hello and welcome to the forum.
Retired trike builder.
trike lady is offline
post #4 of 9 (permalink) Old 09-18-2019, 12:24 AM
Year: 1992
Model: Aspencade 1500
Sounds like a host of bad connections and iffy switches. Time to pull out the wiring diagram, test meter and some contact cleaner and trace things out. You probably have several faults that are interacting with each other.
RambozoClown is offline
post #5 of 9 (permalink) Old 09-18-2019, 12:32 AM
De Motormuis's Avatar
Year: 1995
Make: Honda Goldwing
Model: GL 1500 SE
Hallo Robert Pryor
Welcome on this nice forum. Wish you al the best.
And good luck with your Wing.
__________________
Greetings Wil.
It is beautiful on the road with all the Goldwings.
A Goldwing rider is a happy rider.
See my Albums to see what my nickname means, and see photo's from our holiday in Australia.
Also see my other albums from my motor holidays.
Look in My Garage for photo's from my Goldwing
GL 1500 SE. Two tone green.
De Motormuis is offline
post #6 of 9 (permalink) Old 09-18-2019, 01:04 AM
BLUTHUNDR31's Avatar
The "dreaded Hazard switch stuck" issue , , ,its an easy enough fix. The turn signals will only work correct once you fix that hazard button. Split the switch assembly, two screws on the bottom, , carefully separate the halves and get some contact cleaner deep inside the button and "work" the hazard button until it "releases" normally. Once its clean, your turn signals will snap back to normal operation for you.
That reverse issue is a fairly common issue, , you'll find the answers as long as you read, and read, and read some more using the search feature here using "reverse not working" (or similar wording).
This might help, , https://www.goldwingfacts.com/forums...doesn%27t+work
BLUTHUNDR31 is offline
post #7 of 9 (permalink) Old 09-18-2019, 07:07 AM
DenverWinger's Avatar
Could be a questionable ground somewhere, too. This can make multiple things act wacky all at once.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #8 of 9 (permalink) Old 09-18-2019, 10:56 AM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Robert, About the reverse, check this connection....!
Check the Red 4-pin connector (green, light blue, white/blue, brown/white wires) under the seat (at the rear, left front edge of the trunk). This is the power for the starter relay regulator. The connector might be loose, disconnected, dirty or contaminated.
DBohrer is offline
post #9 of 9 (permalink) Old 09-25-2019, 07:06 PM
Year: 2010
Model: GL1800-Made in USA
You're never too old....
FredFromArnold is online now
  Steve Saunders Goldwing Forums > Forums > New Members Introduction Forum
