GL1000/1100/1200 Single Carb Conversion 2 Barrel 32DFT Progressive Runs Excellent - Page 115 - Steve Saunders Goldwing Forums
 24Likes
post #1141 of 1292 (permalink) Old 11-29-2014, 05:14 PM
Model: '82 GL1100 naked
If you have a drill press and some hole saws and you can solder some plumbing pipes together you could build this manifold, pretty well all from stuff you can buy at Home Depot or a plumbing store. I did it because I thought that the super heat conductivity of copper would result in warm runners and plenum but there is just too much heat taken away by the air/fuel going through the runners for that to work.
It is all made of 1" copper plumbing pipe. I used a 2" end cap for the plenum. The flanges for the runner ends and the plenum flange are made of 1/4" brass. The plenum flange is made to accept the Transdapt 2025, 2 to 1 carb adapter.
With the Weber 32/32 DFT carb it works very well.
End cap/plenum
Flanges have grooves machined for OE Orings.
With Transdapt adapter
On bike
How it runs
https://www.youtube.com/watch?v=rBcF...r#action=share
canuckxxx is offline
post #1142 of 1292 (permalink) Old 11-29-2014, 06:10 PM
Nice!
If you insulate those runners like I do, ...the waste-heat that is transferring to those flanges you made will travel the length of each runner to the plenum and warm it nicely.
Do that, ...and I guarantee that plenum will go from "cold to the touch" to at least "warm to the touch".
Very effective heat transfer happens with the insulators.
Like me, you may be easily tempted to ride without insulators to show-off your work. Get past it if so.
Run those insulators and your engine will smooth out more.
Remember, heating the manifold is purposed to keep the fuel within the charge suspended and continually floating-along with the air. Additionally, a heated tract centers the fuel charge in the tract allowing for (the short version 》) ...more efficency.
The pic tries to convey the message of what is going-on.
Your tract is different above the plenum, but hopefully you get the idea..
CaptainMidnight85 is offline
post #1143 of 1292 (permalink) Old 11-29-2014, 06:18 PM
Insulators are layered with various material (I call them "super-insulators") that rely on 3/4" waterpipe insulating foam that is s sectioned to allow for the larger diameter of the tubing.
Think "pot holders" made for grasping stuff from the oven as being incorporated into the insulators, ...along with "heavy duty" aluminum foil..
The difference is worth the small effort required to make them.
The more heat that you can retain, ...the better. Especially at those elbows. Nice job on grooving those for o-rings.
You have all the heat you need in going that route.
Realize it.
post #1144 of 1292 (permalink) Old 11-29-2014, 06:26 PM
If your carb was turned 90, your tract would look more like this. With that 2-to-1 adapter, it doesn't matter though.
...break out your crayon's
alanc1100 likes this.
post #1145 of 1292 (permalink) Old 11-29-2014, 06:36 PM
...copper:
post #1146 of 1292 (permalink) Old 11-29-2014, 06:38 PM
...Solex example:
post #1147 of 1292 (permalink) Old 11-29-2014, 06:39 PM
Heat retaining black finish:
post #1148 of 1292 (permalink) Old 11-30-2014, 07:28 AM
It would be interesting to try insulating the runners and plenum although I am sceptical that it would make a huge difference.
The bike runs absolutely fine now with no added heat; no bogging or hesitation while accelerating and a nice smooth idle even before complete warn-up. I think it is due to the very small plenum volume and small runners...fuel/air is kept at a high velocity at all times.
I have not done extensive road testing because winter has set in so I'll have to wait 4 or 5 months to test more.
I have another single carb setup, with full coolant heating to the plenum, that I ran all summer and I have complete confidence in. This is an experimental thing to see what could be done with no heat but a smaller plenum.
Brian
post #1149 of 1292 (permalink) Old 11-30-2014, 07:44 AM
...Solex example:
Is that 1 1/4" copper pipe?
post #1150 of 1292 (permalink) Old 11-30-2014, 08:03 AM
I don't remember...
If I do remember correctly though, someone here built it.
...a couple years ago, ...maybe.
I've so many reference pictures that it became hard to keep track of the who, where and when of them all.
I realize it runs great. Video shows so..
It may run smoother and more efficient with added heat.
The insulators do work to remedy the exact issue you noticed and described in your video.
I thought I'd post to let you know what has worked for me in dealing with the same issue.
Speed and Velocity of the mixture can be friend or foe.
Heat tries to befriend and aide Speed or Velocity.
Your heat is free for the grabbing. What's to loose in running insulators for a month or so to know if what I'm saying is true?
Tune it your best without...
...then try it with.
Chances are great that you will notice a difference and need to retune.
