GL1000/1100/1200 Single Carb Conversion 2 Barrel 32DFT Progressive Runs Excellent - Page 128 - Steve Saunders Goldwing Forums
 24Likes
post #1271 of 1292 (permalink) Old 02-20-2017, 08:39 PM
BrianInPA's Avatar
Originally Posted by dshind View Post
Hello
I have a gl1200. I bought the single carb kit on ebay from Juan in ca. It came with a 34pict3 Empi.Never could make it work right.I complained to Juan and he is sending me another like I already had. Can anyone give me a source to get a different carb that will work right outta the box and fit my 1 barrel intake? I am getting pretty well fed up with what I have and feel a little screwed.Any help would be greatly appreciated. Thanks Dave
That's the setup I have on my 81 with a 1200 motor. I did have to adjust the jet sizes a little to fine tune the carb.
Work right out of the box... I don't think there is anything like that, but rather minor adjustments until you get something you are happy with.
Brian
BrianInPA is offline
post #1272 of 1292 (permalink) Old 02-21-2017, 05:14 AM
Year: 1984
Make: goldwing
Model: gl1200 trike
Can you tell me the jet sizes you used? Maybe that will be my next step. Thanks for the reply. Dave
dshind is offline
post #1273 of 1292 (permalink) Old 02-21-2017, 07:42 AM
BrianInPA's Avatar
Sure...
The idle jet came stock at .55mm but it was idling too rich. It is currently approximately 0.30mm. Approximately because I cannot be sure the hole didn't elongate as I drilled it out. I soldered the jet and then increased the size of the jet until I was happy with the idle.
The main jet is a 1.35. Stock was 1.275. I bought a few different sizes and kept increasing the size until I like the acceleration. It takes patience because you also need to contend with the acceleration pump dumping fuel into the carb under heavy acceleration. Turn that back to the lowest setting and get everything running good, then fine tune from there.
Brian
post #1274 of 1292 (permalink) Old 02-11-2018, 12:08 PM
JRod's Avatar
Year: 1978
Model: GL1000
I'm totally going to rock this mod.
<chomping at the bit>
JRod is offline
post #1275 of 1292 (permalink) Old 02-11-2018, 01:08 PM
81 GWing's Avatar
Model: 81 Intrestate
Dirt Road Cowboy likes this.
81 GWing is offline
post #1276 of 1292 (permalink) Old 02-11-2018, 01:13 PM
Good fabrication job!
NASR 12 in Galena, IL
post #1277 of 1292 (permalink) Old 02-11-2018, 01:16 PM
81 GWing's Avatar
it idles way better and the hesatation is gone that ive been fighting with
AZgl1800 likes this.
81 GWing is offline
post #1278 of 1292 (permalink) Old 02-11-2018, 01:21 PM
81 GWing's Avatar
ive seen other ones that are heated...did mine a lil different
File Type: jpg 21367027_10213720690722250_6981007084440549311_o.jpg (62.3 KB, 6 views)
File Type: jpg 21367000_10213720691402267_999353413812770424_o.jpg (47.3 KB, 7 views)
File Type: jpg 21366727_10213720692082284_6297295990211686071_o.jpg (55.7 KB, 6 views)
File Type: jpg 21366697_10213720691002257_4634048222171734896_o.jpg (53.3 KB, 7 views)
AZgl1800 and Dirt Road Cowboy like this.
81 GWing is offline
post #1279 of 1292 (permalink) Old 02-18-2018, 01:22 PM
81 GWing's Avatar
81 GWing is offline
post #1280 of 1292 (permalink) Old 02-18-2018, 04:07 PM
your link did not work, is it "Open to the Public" ??
I use www.Imgbox.com a lot, it gives Full Screen displays of what you upload to it.
here are some pictures of my backyard patio
https://imgbox.com/g/CjpKxDTGdb
we like this one https://images2.imgbox.com/56/69/joc8ez4w_o.jpg
