GL1100 Single Carb Manifold Option - Page 16 - Steve Saunders Goldwing Forums
 20Likes
post #151 of 210 (permalink) Old 09-16-2015, 01:47 PM
Year: 2012/1983
Make: Harley Road Glide/Honda Goldwing
Model: GL1100 Interstate
Has anyone tried adapting a Weber 2bbl to an 1100?
stitches1415 is offline
post #152 of 210 (permalink) Old 09-16-2015, 07:42 PM
BrianInPA's Avatar
Several. Google 32 DFT. There is a thread here if you care to read through the 1200 plus posts. Most of the other forums that focus on 4 cylinder wings also have threads on the subject. Some people will say that it is the only carb that will work and it has to be done a certain way or your single carb conversion will not work... I say read what you see and on all the forums and you will see what the truth really is.
Brian
BrianInPA is offline
post #153 of 210 (permalink) Old 09-20-2015, 05:04 PM
https://www.goldwingfacts.com/forums/...excellent.html
post #154 of 210 (permalink) Old 09-27-2015, 05:44 PM Thread Starter
dkl
dkl's Avatar
Model: 82 GL1100 ASPY, 82 naked, 81 scc naked wings
a little change to design
I have been running the VW 34-3 carb over a year on my PVC set-up, it is reliable, powerful, cheap, and simple. It is on the Black 81 1100, and I also pull a trailer. The Yellow 82 in picture has factory carbs, my better half rides it on our trips. This gives a comparison from single to factory. We are heading to Talimena Trail for a 5 day camping trip week of Oct 12.(Ark, La, Okla, & Texas)
p.s. pictures are of PVC manifold I am building for the 82 for when the factory rack gives up the Ghost. It is same design I have used for over a year, except the 45s are twisted just a little less than 1/4 inch, this gives the correct angle to fit into the factory manifold Ells, and the Flex PVC is no longer needed....Easier and Cheaper........ I also use 1 x 1 1/4 PVC slip by slip bushings to fit on end of 1" runners to slip into existing rubber manifold ells. They fit tighter than the 1" couplings and are stronger.
MY BABY!!
dkl is offline
post #155 of 210 (permalink) Old 09-27-2015, 07:28 PM
Dirt Road Cowboy's Avatar
Model: GL1000
dkl,
I like that assembly jig that you made. It looks like it would keep all your builds consistent.
CaptainMidnight85 and dkl like this.
1978 Honda GL1000
DirtRoadCowboy.com
Dirt Road Cowboy is offline
post #156 of 210 (permalink) Old 10-02-2015, 10:28 AM
randakk's Avatar
Model: multiple GL1000s, CBX, CL350 AHRMA race-bike, CB1100F
This is what you need for best results with a 32/36 2-barrel Weber!
Randall Washington (Randakk)
Founder - Randakk's Cycle Shakk, LLC
Pinehurst, NC USA
randakk is offline
post #157 of 210 (permalink) Old 10-02-2015, 12:32 PM Thread Starter
dkl
dkl's Avatar
Maybe it would be a great carb, but the purpose of this thread was to keep it simple, and cheap. Purchasing a $250 CARB and then modifying it to be acceptable was not directed to the audience I was speaking. This build is for people on a budget, and like me, do not know a Jet from a paper airplane.
MY BABY!!
dkl is offline
post #158 of 210 (permalink) Old 10-02-2015, 02:41 PM
randakk's Avatar
That's actually a $40 EBAY carb (Weber 32/36 DFV). One of the best and most flexible carbs ever made. It can easily support the needs of vehicles from 40hp to 300+
I have 2 on the bench at the moment. Contrary to what you may hear, I actually like tinkering with single carb conversions.
Armed with the rest of the hardware shown above in my photo, you could build a GoldWing with world beater performance. As they say - "some assembly required!"
Pinehurst, NC USA
randakk is offline
post #159 of 210 (permalink) Old 10-02-2015, 02:45 PM
Hi Randall,
looks like some "assembly" is still needed in the photo above... no brakes or throttle on those handlebars yet.
post #160 of 210 (permalink) Old 10-02-2015, 02:49 PM
randakk's Avatar
Hi Randall,
Correct.
That's a "mockup" assembly to check some frame modification details + the new front end (modified CB900F).
The bike is apart again while we work through the rear suspension mods and other details before the frame goes out for finishing.
Pinehurst, NC USA
randakk is offline
L.D. Wingnut Single Carb Manifold scottdaz Altered Induction 10 06-07-2015 01:57 PM
Looking at this single carb manifold chilidawg Altered Induction 9 02-03-2014 02:15 AM
GL1100 Source for single carb manifold? bbells For Sale/Wanted Forum 0 06-21-2012 12:47 PM
jetting for gl1100 with single carb manifold and solex 30/31 pict JJB Altered Induction 2 07-23-2011 12:00 PM
Single carb manifold All out Alex Goldwing Technical Forum 11 09-26-2008 08:44 AM
