GL1100 Single Carb Manifold Option - Page 19 - Steve Saunders Goldwing Forums
 20Likes
post #181 of 210 (permalink) Old 01-21-2016, 04:41 AM Thread Starter
dkl
dkl's Avatar
Model: 82 GL1100 ASPY, 82 naked, 81 scc naked wings
Absolutely, I plan on documenting start to finish. The 82 stock runs great as it is, I am changing for dependability for long trips. I can go back to stock rather quickly if I want. No cutting or changing of bike is required, the mods I do to Enclosure and such are because I just want to.....The pull throttle cable is the only part on stock bike that must be cut for conversion.
The Yellow is 82, picture from this summer Arkansas trip waiting out rain.
File Type: jpg 11295935_506884416126062_318419932633091846_n.jpg (38.0 KB, 14 views)
MY BABY!!
dkl is offline
post #182 of 210 (permalink) Old 02-21-2016, 05:32 PM Thread Starter
dkl
dkl's Avatar
This is my wife's 82GL1100 mounting my Manifold and 34-3 VW carb. $30 worth of PVC, $12 air filter, $89 VW34-3 carb.....and the only thing cut on the GL1100 is the little end on the Pull Throttle Cable.
CaptainMidnight85 likes this.
MY BABY!!
dkl is offline
post #183 of 210 (permalink) Old 02-21-2016, 05:53 PM
Very good demonstration, I don't perceive any loss of performance compared to the OEM carbs...
maybe at full throttle in 5th gear?
post #184 of 210 (permalink) Old 02-21-2016, 06:16 PM Thread Starter
dkl
dkl's Avatar
I can skat to 90 with a ton of power,,,,,but after that the jump is gone, will keep getting faster but it is gradual.,,top end speed over 90 is the trade-off, but that is a place I do not care to travel.
MY BABY!!
dkl is offline
post #185 of 210 (permalink) Old 02-21-2016, 06:35 PM
You're right DKL, that Solex automatic electric choke is beautiful. I miss it in using my Weber. You don't have to touch a thing with that Solex once set up.
If yours works anything like mine did when I ran it (the Brosol H-30/31 variant), it should fire right up down into single-digit temperatures with no problems.
If I wasn't so heavy-handed and now lazy with my cold weather riding, I'd still be running that Brosol. It's better suited for my climate if riding all year.
I like the fact that you've stuck with the whole idea more than anything. You've made it work for yourself. PVC (or is it CPVC) and a Solex do work. You've shown that it lasts as well.
Good Job!
CaptainMidnight85 is offline
post #186 of 210 (permalink) Old 02-28-2016, 07:55 PM Thread Starter
dkl
dkl's Avatar
On the 82 GL1100 I used 1" Sch 40 PVC pipe and Fittings. I no longer use Flex PVC, it worked well but had to be supported or it would sag some in the middle.
I use 4 PVC Socket Bushings 1 x 1 1/4 to go inside the stock rubber manifold ells. I also use the 1" side outlet cross in the middle, and a 1" socket floor flange to mount the 34-3 carb and Four 1" 45 degree ells.
Here are some random pictures of my build, and the Jig I use to build my manifolds. I get the correct amount of drop for the runners by twisting the 45 degree ells until they touch the Jig.
MY BABY!!
dkl is offline
post #187 of 210 (permalink) Old 03-28-2016, 08:14 PM Thread Starter
dkl
dkl's Avatar
Easter 2016 Camping Run--2 bikes--2 singles
Bikes ran great on camping trip. This video shows bikes packed and ready to Pull out for Home.
MY BABY!!
dkl is offline
post #188 of 210 (permalink) Old 03-28-2016, 08:20 PM
post #189 of 210 (permalink) Old 04-10-2016, 08:51 PM Thread Starter
dkl
dkl's Avatar
DKL PVC MANIFOLD v2.0
Not much activity Here, but I figured if someone wants a easy conversion set-up to get their Wing going....This is it. I run the VW34-3 Carb and it works well for my GL1100s. I have used PVC Manifolds for 3 years with no problems, this is my simplest version yet, and runs really Good.
Schedule 40 PVC: 3 each 1" PVC Sling Tee, 4 each 1" Street Elbow, 2FT 1" PVC Pipe, 1 each 1" PVC Floor Flange Nibco Sch 80
MY BABY!!
dkl is offline
post #190 of 210 (permalink) Old 04-10-2016, 10:41 PM
Year: 1985
Model: 1985 Gl1200A
1) post your dimensions for the fitting framjes
2) How do we find cthose TEEs you mentioned
froche is offline
L.D. Wingnut Single Carb Manifold scottdaz Altered Induction 10 06-07-2015 01:57 PM
Looking at this single carb manifold chilidawg Altered Induction 9 02-03-2014 02:15 AM
GL1100 Source for single carb manifold? bbells For Sale/Wanted Forum 0 06-21-2012 12:47 PM
jetting for gl1100 with single carb manifold and solex 30/31 pict JJB Altered Induction 2 07-23-2011 12:00 PM
Single carb manifold All out Alex Goldwing Technical Forum 11 09-26-2008 08:44 AM
