78 Gl1000 single carb conversion - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 03-14-2015, 09:08 AM Thread Starter
newtscoots's Avatar
After attempting to rebuild my gl1000 carbs for the third time I have given up - runs okay - but the gas mileage is horrific. I have bought a single carb conversion manifold & carb - unfortunately came with no instruction. I am wondering about the electric choke setup -how to wire it? Or should I just hook up a manual choke to it. Also looks like a pre heater or something like that at the bottom of the carb - is that needed? I will only be running it in warm weather. Any instructions / advice would be appreciated.
Merv
1978 GL1000 1974 CB750
newtscoots is offline
post #2 of 14 (permalink) Old 03-14-2015, 09:24 AM
Big Cahuna's Avatar
I think a manual choke will be easier to hook up and deal with, then trying to figure out a electric choke setup.,,
Bikes Ive owned, \'69 Norton,\'48 Harley panhead, \'71 Bsa, \'76 gl1000,\'93 Harley ultra,\'03 Harley ultra,\'05 Sportster, \'82 GW 1100.\'96 Police road king very used. "I tried thinking once, but nothing happened" .,,,
Big Cahuna is offline
post #3 of 14 (permalink) Old 03-14-2015, 09:52 AM
A picture of your conversion would help in my opinion.
Too many conversions out there for a simple answer ...from me, anyway.
CaptainMidnight85 is offline
post #4 of 14 (permalink) Old 03-14-2015, 10:11 AM
Model: 1976 LTD (X2) (two apart in VIN)..... 2008 Pearl White
77Pinto is offline
post #5 of 14 (permalink) Old 03-14-2015, 02:14 PM Thread Starter
newtscoots's Avatar
Thanks - I will try to get some photos on tomorrow - I am a little technically challenged - I have them on my i-phone and can send as e-mails - not quite sure how to put them on here. Would try to figure it out today - but the wife just pulled in with the truck - am going out to figure out how to replace the cv joint in an Avalanche - I probably wont be back on forum till tomorrow.
Merv
post #6 of 14 (permalink) Old 03-14-2015, 04:11 PM
rayjoe's Avatar
Electric choke
I'm assuming the carb already has an electric choke with a male spade connector on it.
All I did is run a wire that's hot when the ignition is on and a ground wire to the carb body. I used the acc. terminals under the fuse cover for my 12V source.
Worked fine.
Rayjoe
rayjoe is offline
post #7 of 14 (permalink) Old 03-14-2015, 05:24 PM
dkl
dkl's Avatar
Model: 82 GL1100 ASPY, 82 naked, 81 scc naked wings
What carb are you installing on Wing?????
MY BABY!!
dkl is offline
post #8 of 14 (permalink) Old 03-14-2015, 06:18 PM
Model: 1980 1100
So what set up did you buy?
No instructions, was this kit used?
Find it on EBay?
tunaboy is offline
post #9 of 14 (permalink) Old 03-14-2015, 10:00 PM Thread Starter
newtscoots's Avatar
It is a VW type carb - I did buy on E-Bay - new set up. Went back & looked at the listing - and it was supposed to include instructions - seller must have missed them - I have asked him to send them - so I should be on the road soon. Thanks for the info on electric choke - just what I needed - I should be able to get that done now - just figure out the heat element - I would think that I should be able to run the choke and heat element on seperate fuse - I hope I've made the right choice. Just spent way too much down time with carb issues - just want to get some road time in.
Merv
post #10 of 14 (permalink) Old 03-14-2015, 10:36 PM
dkl
dkl's Avatar
Heater at bottom of carb? Is it the solenoid on the VW34-3pict carb u are calling a heater? Just asking.....If it is, just run a jumper wire from choke to solenoid.
MY BABY!!
dkl is offline
GL1000/1100/1200 Single Carb Conversion 2 Barrel 32DFT Progressive Runs Excellent westgl Altered Induction 1298 08-06-2019 03:03 PM
Single carb conversion vs quad carb rebuild Tmc2009 Altered Induction 32 11-22-2014 06:16 AM
