A Tom Langdon Goldwing Weber DFT32 carburetor conversion video - Page 2 - Steve Saunders Goldwing Forums
post #11 of 18 (permalink) Old 08-29-2015, 11:03 AM
That's good.
Video is fantastic.
dunno what you think is so fantastic about the vid, there are a ton of dft32 conversion vids out there with tons of easy to get info, from a to z
folks that have gone there extensively have also not had your results, but they are at least fully open with info and what they are doing with pix, videos etc
whereas,
you have many claims backed up by at most, very difficult to get info of any kind & even today, stuff like this thread starter and ~ "great vid eh?"?!
if this question is too far off whatever the intended topic is in this thread, i'll start another
anyone else have current verifiable results, as in running clean plugs with a langdon carb running stock settings? a thread? links? hopefully other than abandoned threads
there are certainly reports to the contrary, as in a rich condition at low/idle RPMs, along with final tweaking being the norm
even here, i think the main argument is ~ "you must go about it in a specific way" and apparently only one other is heating the manifold in the same way, this after years
the initial reports with this bolt on as is carb also included, info, pix, vids with no heat and clean plugs, tho that fella moved on
my conclusion? currently, this is not a bolt on good to go carb (tho might be some lucky ones) without supporting and easily verifiable info/evidence, or at least some duplicated results,
bits of info scattered here and there to support a claim, and it's been years now, does nothing for scc, other than create problems,
here's another vid
https://www.goldwingfacts.com/forums/...000-frame.html
and much more
https://www.youtube.com/results?sear...32dft+goldwing
82, going over it
had a hog in there for a bit but basically,
back in the saddle after a ~ 24 year break,
at the time, had an oncoming made a left turn deal
pdbro is offline
post #12 of 18 (permalink) Old 08-30-2015, 01:21 AM Thread Starter
Originally Posted by goldwingrascal View Post
PDBRO. i'm having a bit of trouble interpreting whats going on here. mr midnite seems to start these threads and then either has no time or is giving you childish answers .
now, i dont know about you, but i am looking for some info. this forum looks to be a real good one , in other areas of it anyway.
...you can address me.
Do you have a question?
CaptainMidnight85 is offline
post #13 of 18 (permalink) Old 08-30-2015, 01:39 AM Thread Starter
with all due respect mr midnight, i do not wish to address you. one read of this thread was enough. thank you for your interest.
Certainly a intetesting response.
post #14 of 18 (permalink) Old 09-01-2015, 08:54 PM
Year: 1975,1976,1981
wel, i seem to have missed the point of this thread.....
strange interaction to say the least...
quidproquo is offline
post #15 of 18 (permalink) Old 09-01-2015, 08:59 PM
that is because some purposely tried to hijack it and go off topic.
when that happens, I delete the off topic responses.
all will come back in order when time permits Steve to get things situated at home.. right now, the thread and the forum are not his #1 priority. so just be patient. Rome was not built in a day.
NASR 12 in Galena, IL
post #16 of 18 (permalink) Old 09-01-2015, 09:17 PM
ekvh's Avatar
Model: 77/83/85/yup, all of 'em in one
This will never be Rome. I saw no one purposefully trying to hijack and take this off topic. A lot of these get taken off topic by the originator.
ekvh is offline
post #17 of 18 (permalink) Old 09-01-2015, 09:35 PM
after another read of this and several other threads in the same vein,
i tend to agree. a bit of a search for CM here and ( more interestingly)
on other web sites does not paint a pretty picture.
one very popular site even has one whole thread dedicated to the originator . ( less than favorable views , it has to be said )
so, time will tell if there is any substance here.
post #18 of 18 (permalink) Old 03-18-2016, 02:29 PM Thread Starter
Correct. A heated plenum floor is specifically stated by Tom Langdon as a requirement. He states this on every carburetor he sells verbally to the purchaser via telephone. He emphasizes this need to all Goldwinger's as a minumum. It is not optional and he makes that clear.
It is only a argument for those that do not follow his instruction on heating the plenum floor via intimate contact with engine coolant.
There is no argument. Do it or don't. Not my problem..
Your conclusion is easily summarized; There is nothing comparable to give you any support to the evidences you are seeking.
The Jessco tuned-port manifold has no comparison.
Your conclusion is relevant to what exact point?
Carburetor goldwing 1997 carburetor idle problem - Need Spanish speaker here Ramonvela439 Goldwing Technical Forum 6 09-28-2015 11:53 AM
VW Type IV Manifold and Tom's Carter/Weber 32DFT... RhinoWing Altered Induction 2 06-07-2015 08:00 AM
A great video for you Major Tom fans Bigmick Miscellaneous Forum 2 05-13-2013 08:33 AM
weber conversion stinkyfartur Altered Induction 3 05-08-2009 09:29 PM
