Linux thread - Page 23 - Steve Saunders Goldwing Forums
 59Likes
post #221 of 269 (permalink) Old 02-17-2019, 05:26 AM
Monkey with a Football
Rudy's Avatar
I hate HP and Toshiba BIOS.....
Agree. You can add Sony Vios to that for me.
Some models are fine but you never know when you are going to hit that Sony non-standard stuff.
I'm an Acer laptop fan. Good prices, features and the damned things just work.
Rudy
wasn't too much fun”
Rudy is offline
post #222 of 269 (permalink) Old 02-17-2019, 06:01 AM
I am afraid that Sony Vios is in front of me.
my daughter asked me to put Linux on her ancient Sony laptop, it has been worthless for so long.
if it whips me, I will be hollering at you Rudy.
flylow and AzHonda like this.
NASR 12 in Galena, IL
post #223 of 269 (permalink) Old 02-17-2019, 06:48 AM
Rudy's Avatar
I'll have to send you my hand sledge.
flylow likes this.
Rudy
Rudy is offline
post #224 of 269 (permalink) Old 02-20-2019, 01:04 AM
AzHonda's Avatar
Year: 2006
Originally Posted by Rudy View Post
You can't really shut off the mic and camera unless you either go inside and unplug the connector or put tape over the camera. On a phone, the mic is needed to work so you are hosed there.
On laptops, it's tape on the camera and a dummy plug in the external mic jack. Easy to remove and replace when needed.
That's one of the reasons I like the Toughbook CF30's No mic and no camera.
LOL I do the tape trick on all my devices.
But this is great !! Rudy says : " On laptops, it's tape on the camera and a dummy plug in the external mic jack. Easy to remove and replace when needed."
That is a neat trick.
AzHonda is offline
post #225 of 269 (permalink) Old 02-20-2019, 08:07 AM
Rudy's Avatar
To keep the dummy plug short, I remove the back (toss it) and fold the ground and hot over each other and solder them together making a shorting plug out of it. I cut the ground lug short and bevel the corners so there is nothing sticking out before the folding and soldering is done.
That way you can leave it plugged in when you travel with it.
As I said, be sure to test it. Some laptops have multiple mic inputs and don't run the internal one thru the external mic jack. In that case you either live with it or open the unit to unplug the mic from the inside. If you do that on those, you should still be able to plug in a mic to the external mic jack for use when needed. Actually, you can do that to any of them.
Rudy
Rudy is offline
post #226 of 269 (permalink) Old 02-20-2019, 09:30 AM
Year: 1998
Model: GL1500 SE
The first laptop I ever bought was an Acer. I don't remember the model, I still have it and it has Windows XP on it. The only thing I have on it that I use is a program for my tuner on my Dodge diesel. The program would not run on Window 8 and I have not tried it on 10. It probably will run on ten with compatibility mode but I just leave it where it is. That laptop had an entire cup of coffee drooped into the front and ran out the back. While it was running! Turned it off, pulled the battery out and stood it on end and let it dry out. Worked just fine after that. Second coffee spill got into the screen. (Yea, I have a problem with coffee. It replaced alcohol so I still feel I am better off) The laptop STILL worked fine but the screen had a big semicircle stain on the bottom. I sent it back and even though it was 3 months out of warranty they replaced the screen and my only cost was shipping. Needless to say the rest of my laptops have been Acers. And from what I can gather most of the internal parts of all the brands are made by Acer.
Rickf1985 is online now
post #227 of 269 (permalink) Old 02-20-2019, 11:17 AM
Magic Moderator
trike lady's Avatar
I've got 2 Dells, 2 Toshibas (had 3 gave one away) and an Apple G4PowerBook. The Dell laptops have no problem with any version of Linux, the Toshiba wasn't good with Linux Mint Cinnamon but can handle Xfce and MATE editions. I run Vista on one of the Toshiba laptops as it and 7 are the only ones that can run the cross stitch software. I did have an Acer pc years ago, but switched to laptops.
Retired trike builder.
trike lady is offline
post #228 of 269 (permalink) Old 02-20-2019, 02:00 PM
so far, I have liked the Acer BIOS better than Sony, the HP, and the one Dell that I have worked on.
post #229 of 269 (permalink) Old 02-20-2019, 08:48 PM
Magic Moderator
trike lady's Avatar
How did the Sony turn out? Did it except the Linux Mint?
post #230 of 269 (permalink) Old 02-20-2019, 09:42 PM
got wrapped up in other things.... it is on the back burner, but I will do it just to have it available as a backup for my daughter. I gave it to her many years ago, a decade at least.
  Steve Saunders Goldwing Forums > Forums > Computer Talk
Linux/Limux is not the "perfect OS" that some would believe it to be AZgl1800 Miscellaneous Forum 127 12-29-2015 09:36 PM
Linux... CaptainMidnight85 Miscellaneous Forum 15 04-12-2010 01:06 AM
Linux - Which incarnation do you prefer? AZgl1800 Miscellaneous Forum 15 02-01-2009 02:26 PM
Help........Can't play a CD in Linux Jennifer Miscellaneous Forum 1 02-01-2008 08:07 PM
LINUX saved my a**, I mean, data! SB in SC Miscellaneous Forum 26 11-03-2007 09:31 AM
