85 GL1200 Limited Hesitation - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 07-08-2005, 05:46 PM Thread Starter
MeTnVette's Avatar
I just purchased a GL1200L. It had a hesitation when I purchased, thought injector cleaning would solve. Honda dealer cleaned injectors, new plugs. Called and said Throttle sensor was out. Replaced throttle sensor, still hesitates. They then said it was the ECU. Replaced ecu, now ecu says Throttle Sensor again. The bike has 44,000 miles. Help
MeTnVette is offline
post #2 of 9 (permalink) Old 07-08-2005, 11:26 PM
fatalattraction's Avatar
Sounds like the Honda shop are a bunch of parts changers. Are they still charging you to guess what's wrong? I can't help you but the scenario is familiar. I've seen shops of all sorts that just change parts until they get it right.
Someone will come along and steer you in the right direction. And welcome to the Board. There's a lot of really helpful guys on here.
Now in limbo trying to decide what I want to get.
fatalattraction is offline
post #3 of 9 (permalink) Old 07-09-2005, 04:56 AM
07Silver's Avatar
I know someone in England who had a similar problem. I big lag when he opened teh throttle. The fault code lights in the ECU didn't read faulty at all. Eventually by trial and error and fitting different parts it turned out that the temperature sensor was faulty. The sensor tells the ECU if the coolant is up to operating temp or not (ie hot or cold). A new one solved the problem.
I can't say if this is your problem but I thought I'd pass it on anyway.
And welcome to the forum MeTnVette.
Ambrose Renehan.
GL1800, 2007 silver.
07Silver is offline
post #4 of 9 (permalink) Old 07-11-2005, 12:42 AM Thread Starter
MeTnVette's Avatar
Thanks. The forum hasgiven melots of useful info!
post #5 of 9 (permalink) Old 07-11-2005, 12:44 AM Thread Starter
MeTnVette's Avatar
Thanks ! Great forum
post #6 of 9 (permalink) Old 07-25-2005, 04:00 PM
GERIATRIC MEMBER
Redwing's Avatar
Model: Neighbours 1800
Hey MeTnVette Welcome to the Best Goldwing Forum on the net.
"Redwing"
Redwing is offline
post #7 of 9 (permalink) Old 07-25-2005, 07:47 PM Thread Starter
MeTnVette's Avatar
MyWingis repaired.He said theyreset the ECU andsynchronized the fuel injectors. No hesitation! Loving my Goldwing! Great Forum
post #8 of 9 (permalink) Old 10-15-2005, 09:20 PM
flyingcop2005's Avatar
Send a message via AIM to flyingcop2005 Send a message via Yahoo to flyingcop2005
help! i have the same wing with the same problem but no dealer here will touch it! how do you reset the ecu?
Riding has renewed my spirit after so much tragedy.....
1976 honda 550
1982 honda 750
1985 goldwing limited
flyingcop2005 is offline
post #9 of 9 (permalink) Old 10-15-2005, 10:01 PM
Senior Guru
Oregonwinger's Avatar
Go to search, and type in LTD. There's a lot of stuff about LTDs. There's no resetting these ecu's. They're not adaptive. He porbably just thot he reset it. Sync is pretty important, and if on the original job, they forgot to hook up air temp sensor, that'll make it doggy. Glad it's fixed. They're pretty incredible, when they're right. I've thought about converting mine to GM injection. That way, it would be laptop accessable, + scanner (OBDI) Maybe, someday. I might do it to an Interstate, instead. I have most of the goodies to do it.
BOB
Oregonwinger is offline
85 gl1200 limited edition dgoins Goldwing Technical Forum 4 10-04-2011 06:56 AM
1985 GL1200 A Hesitation, miss, bog, etc. outofcontrol Goldwing Technical Forum 52 09-19-2009 12:07 AM
1985 GL1200 Limited Cowboy26a For Sale/Wanted Forum 20 01-04-2009 03:26 PM
Restorted Gl1200 Limited YukonHonda Goldwing Technical Forum 11 07-14-2005 04:08 PM
GL1200 Limited Edition CB Long Hair Goldwing Technical Forum 4 04-12-2005 12:53 PM
