1978 GL1000 No Power to Headlight - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 09-03-2005, 09:59 PM Thread Starter
ElvisTorino's Avatar
I recently pulled a Vetter fairing off of this thing and assorted other junk that hadn't been wired in neatly, and I've figured most everything else out, but I can't figure out why I have .1V (max) to one of the terminals in the headlight connector. The manual (factory) doesn't have a wiring schematic and the fuse is good...I'm lost at where to start trying to hunt down the wires.
All the stuff in the light switch on the bars is working (turn signal switch, horn) but I can't really tell with the headlight as I haven't torn it apart to check.
I'm looking for a harness connector where I might be able to check for voltage for the headlight, between the fuse and the headlight connector. Any clues would be great.
Oh, I've only been perusing here for about a week, and I just got my GL1000, dern fuel prices. But its going along fairly well save for that. This appears to be a pretty great site, I've gathered a fair bit of info here.
--T
1978 GL1000
ElvisTorino is offline
post #2 of 7 (permalink) Old 09-04-2005, 08:11 AM
wingdawg101's Avatar
ElvisTorino,
Welcome to the "WGGWWS" !!
I'm not good with "wiring or the 1000's but some one will be ny soon who is, probably "Twisty" or "Jason" etc!
Since you're in "Roswell, NM" I'm sure it's a "UFO" that shut your headlight down,LOL! Couldn't resist that one, you knew it was coming,huh?!
I live a stone throw away from "Area 51" so we're even! good luck! Pete
PS you can go to "nakedgoldwings.com" and ask there, it's mostly 1000's!
Against the Wind !
"Patriot Guard Rider"/Nevada
GL 1100
Valkyrie "Fat Lady"
wingdawg101 is offline
post #3 of 7 (permalink) Old 09-04-2005, 02:14 PM Thread Starter
Here's the current (no pun intended) situation.
I have voltage (battery) to the headlight plug. I have a good ground to the headlight plug.
When I plug in the headlight assy, they all appear to go to ground, no voltage. When I jump the light to the battery it lights.
I have a Halogen H4 bulb that I'm using. Is this the problem? If so, can someone recommend a solution?
--T
1978 GL1000
post #4 of 7 (permalink) Old 09-04-2005, 02:22 PM
Tonys96's Avatar
Sounds like yoou've answered your own question,
Bulb good
Wiring to bulb connection good.
Replace bulb connector, probably an internal short.
Tony
89 GL1500
Tonys96 is offline
post #5 of 7 (permalink) Old 09-04-2005, 06:54 PM Thread Starter
the problem was a loose wire at the headlight fuse panel.
1978 GL1000
post #6 of 7 (permalink) Old 09-04-2005, 11:07 PM
Thanks for letting us know , may save us time one day!
Against the Wind !
GL 1100
Valkyrie "Fat Lady"
post #7 of 7 (permalink) Old 09-05-2005, 10:44 AM Thread Starter
It appears that in the past someone cut the wire from the fuse (the protected side, not the battery side) for some reason.
1978 GL1000
1978 GL1000 F/S Kefltrvlr2 For Sale/Wanted Forum 0 04-01-2011 09:08 AM
Is a 1976 GL1000 interchangeable (all parts) with a 1978 GL1000? ryster Goldwing Technical Forum 11 12-16-2010 11:11 AM
In search of 1978 GL 1000 headlight and ring, front turn signals ryster For Sale/Wanted Forum 0 04-02-2010 09:55 PM
1978 GL1000 pacific cruzin Goldwing Technical Forum 10 09-26-2008 04:51 PM
1978 GL1000 ChaseJulius2 For Sale/Wanted Forum 0 06-23-2008 05:05 PM
