"79 Wing Float level - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 10-07-2005, 10:56 AM
Guest
Posts: n/a
In my "75 - 79 Service manual (page 9-21) it shows how to set the float level on the carbs. It shows 21mm as the measurement. However the picture is not very good and I cannot make out where this measurement it taken.
I bought this machine with 23K miles on it this spring and it had been service by a local "fix all" motorcycle shop. Three out fo the four carbs leak, a sure sign that the float levels are wrong. I also have a'77 wing with 73K miles on it.
Thanks in advance.
B. J. Baum
Decatur, IL
post #2 of 3 (permalink) Old 10-07-2005, 01:16 PM
Try this link and good luck. Also, the leaky carbs you speak of could have a bad valve (or after market), not necessarily a bad level. Pull the float off (be very careful not to break off the post when you remove the pin) and check for groves in the rubber tip of the valve. Also check out Randakk Gl1000 web site. He has info on float valves, and the info below is from him as well.
Lou
http://groups.msn.com/ClassicWingSIG..._Message=15991
enterocin is offline
post #3 of 3 (permalink) Old 10-07-2005, 01:54 PM
twisty's Avatar
Thanks in advance.
B. J. Baum
Decatur, IL
B.J., you might want to look at this thread of a few days ago. Look down the page a ways to about post 8 or so.. Then drop down to #17 on the list posted..
https://www.goldwingfacts.com/forums/forum1/4858.html
Twisty
twisty is offline
Float level Conflict rideandslidejim Goldwing Technical Forum 2 03-11-2011 07:16 PM
GL1200 Float level GreyDino Goldwing Technical Forum 7 02-27-2011 06:47 PM
FLOAT LEVEL GL1200 Bike...and Dennis Goldwing Technical Forum 45 07-26-2010 12:21 PM
Float Level Victour78 Goldwing Technical Forum 14 07-25-2009 04:09 PM
GL1200 Float Level Xtracho Goldwing Technical Forum 2 06-07-2009 07:59 PM
