Brake Rotors - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 10-17-2005, 05:16 PM Thread Starter
outlawearl's Avatar
How bad can they be & still use them. I am replacing pads on the back of my 82 GL1100I & really don't want to take all my light bars & bags off & pull the wheel if I don't have too.
1982 GL1100I
outlawearl is offline
post #2 of 8 (permalink) Old 10-17-2005, 05:54 PM
Let me try to answer this one, at least until a guru chimes in.
I think there is a minimum thickness that it can be used and still be safe. That way it shouldn't be a concern that the rotor will crack and shatter. If the surface is heavily groove, there will be less contact for the pads and therefore less braking action, not mention wear. Sometime, the surface finish can induce brake squeal or chatter. Brakes are one thing I would not even consider taking any shortcuts on.
87 GL1200I Grey
03 GL1800 Red
wingmaster is offline
post #3 of 8 (permalink) Old 10-17-2005, 06:20 PM
jackjohn's Avatar
Hi Earl, the minimum thickness on the '82 Interstate or Standard is 6mm (0.240) as Wingmaster says, anything less than that is dangerous to the point of possible crack or shatter. It takes a lot of pressure and heat to bring a GoldWing to a halt from a high rate of speed. Don't chance it, get another one.
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #4 of 8 (permalink) Old 10-17-2005, 09:36 PM
wingdawg101's Avatar
They are getting hard to find, might have to try E-Bay?
Against the Wind !
"Patriot Guard Rider"/Nevada
GL 1100
Valkyrie "Fat Lady"
wingdawg101 is offline
post #5 of 8 (permalink) Old 10-18-2005, 11:45 AM Thread Starter
outlawearl's Avatar
Ok, I have done some checking around & to get a new one is $200.00. They all tell me that you can not turn down the old ones. If I go for a used one, am I not just going to get the same thing I have on the bike now?? Money is an issue here as I don't really don't have that much to spend on a Rotor. Is it really true that these can not be turned down??
Thanks
1982 GL1100I
post #6 of 8 (permalink) Old 10-18-2005, 11:48 AM
How bad is yours? Some grooving is okay. You might want to measure the thickness and see how thin it is. If it meets the minimum that jackjohn gave you and the grooving isn't severe I'd replace the pads. The rear brake is important, but the main part of the effort braking is on the front brakes.
post #7 of 8 (permalink) Old 10-18-2005, 02:40 PM
My Brothers friend got lucky, bought some from E bay and they looked like new, very thick and not warped, $45 ?!
Against the Wind !
GL 1100
Valkyrie "Fat Lady"
post #8 of 8 (permalink) Old 10-19-2005, 02:15 AM
BRowan's Avatar
When I got my 1200, the front ones were down to 4mm and there were little cracks visible. I got worried enough to buy a good used set. If I'm not mistaken, the gl1100 rear can be bought new for something like $160 because someone posted this a few months ago.
Brian Rowan
BRowan is offline
GL 1100 brake rotors Stinky151 For Sale/Wanted Forum 6 09-01-2009 09:28 PM
Brake rotors Firemedic268 General Motorcycle Discussion Forum 1 07-09-2009 05:45 AM
Brake rotors Wishiewashie General Motorcycle Discussion Forum 5 05-05-2009 06:14 AM
Brake Rotors rhughes Goldwing Technical Forum 8 10-26-2008 11:39 AM
E.B.C. Brake rotors Goldwinger General Motorcycle Discussion Forum 7 11-23-2006 12:55 PM
