throttle cable - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 10-21-2005, 06:13 PM Thread Starter
Vivian's Avatar
can anyone give me any advice on fitting a new throttle cable to a 1989 GL 1500
only skydivers know why birds sing
87/88 CBR 1000
89 GL 1500 with sidecar
SHINE ON YOU CRAZY DIAMOND
KEEP IT LIT (JOEY DUNLOP 3)
Vivian is offline
post #2 of 9 (permalink) Old 10-21-2005, 07:02 PM
What exactly do you mean by "fitting"? Are you installing a replacement cable? Adjusting the original cable?
Old Nam Vet
LZ English 66 - 67
New \'08 Titanium Nav
I\'m old and wise, but was once young and stupid.
Renegade is offline
post #3 of 9 (permalink) Old 10-21-2005, 07:49 PM
Tonys96's Avatar
To "chase" the new cables I always use duct tape and tape them to the old one I'm removing.
As far as getting to the throttle cable at the carb, well there's quite a bit of bike to be removed.
If you take your time and look where the old cable is routed it should work out for you.
Tony
89 GL1500
Tonys96 is offline
post #4 of 9 (permalink) Old 10-22-2005, 02:04 PM
Vivian, you will need to remove the saddle, false tank sides, console and side panels. With the tank panels off you will be able to see the cable route. I did mine once and taped the end of the new one to the old one and pulled it down, but it got stuck on a bracket and I had to spend some time fiddling with it. You don't have to remove the carbs to do this job, but if you ever have to replace the choke cable you will have to pull the carbs first.
Al.
BigAl is offline
post #5 of 9 (permalink) Old 10-23-2005, 11:47 AM
JDuggan's Avatar
Vivian, the bracket Al is talking about has to be the one on the left side of the left carb. You can get a screwdriver to this and pry it open a bit if the cables snag. Its not too hard a job to do, stripping the plastics is the time consuming part.
Joe Duggan
JDuggan is offline
post #6 of 9 (permalink) Old 10-30-2005, 09:21 AM
DJ
The throttle cables are easy enough to do. The real hard one is the choke cable, you need to pull the carbs back to get at it.
DJ is offline
post #7 of 9 (permalink) Old 10-31-2005, 03:04 PM
Older and Wiser
BenMC's Avatar
Model: GL1500 Aspencade
I did this job a few years back. Took me about 3 hours from start-finish and I didn't have to pull the carbs out.
Ben.
BenMC is offline
post #8 of 9 (permalink) Old 11-01-2005, 02:40 PM
DJ
Any updates on this Vivian? I'm sure we aould all like to know how you fared, if you fitted the cable yet.
DJ is offline
post #9 of 9 (permalink) Old 11-02-2005, 10:24 AM Thread Starter
Vivian's Avatar
I did'nt try any short cuts took off the neccessary panels and body work fairly straight forward but fiddley skint a few knuckles. I hope I dont have to do it again any time soon.
Thanks to everyone for their help and advice
87/88 CBR 1000
Vivian is offline
GL1500 throttle cable disaster.. how to get the cable out?? pippomaranga Goldwing Technical Forum 3 05-25-2012 12:06 PM
throttle cable nick83gl Goldwing Technical Forum 1 09-12-2009 11:34 AM
Wanted To Buy-mid Sixties Honda 90 Throttle Cable Assembly; Throttle Cables; Lens dean For Sale/Wanted Forum 0 01-04-2009 03:33 PM
throttle cable junemann Goldwing Technical Forum 5 08-13-2008 09:00 AM
Throttle cable CRAIGA Goldwing Technical Forum 5 10-11-2005 08:26 PM
