Tips for Air Vent Removal - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 10-31-2005, 04:56 AM Thread Starter
Passed On, R.I.P.
Mohawk's Avatar
Location: Baldwinsville, Just Outside of Syracuse, New York, USA
Model: 09 Gl1800
I have read a few posts about how carefull and scared we are when we have to remove the Air Vents on our wings. A couple of guys in my club just took them to the dealer so when they broke it they replaced it. The below has worked for me and a few guys in my Club when they tried it so here ya go.
Tips for Air Vent Removal.
On the Tabs for the Upper and Lower Vents, I usetools made from Large Paper Clips. Use the Steel Clips Not Aluminum and go for the Smooth ones not the Grippy ones with the serrations.
Now just staighten the first leg of Clip, and bend the very end portion. About 1/8", or .125" Long, or about 3mm long, for our Metric friends. I bend them past 90 degrees around 120 degrees. This helps when you use them as a hook to pull the vent out.
Now you have a tool to help unclip the plastic tabs and use another clip to to help pull vent toward you.
Slide the first clip in the little crack on either side of the Tabs. Now rock or twist it to the side and the tab will be pulled up slightly. With your other clip you can reach in and hook the back of the vent and pull slightly so the tab is not locked to the hole anymore.
Move to the other side and repeat. I do the bottom ones first and then kind of roll the vent out. On some I have had to do the top clips first. ( You may need a Mirror to see the clips on the tops) then the bottoms, as the bottoms are the easiest to see. Then Pull out the vent.
I have performed this about 6 or 7 times with no tabs broken yet.
Good Luck
Mohawk
95 Aspencade, Dressed to the Nines
Live to Ride - Ride to Live
My 4th Wing with 43 Years in the Wind Now
I have owned over 50 bikes now, This is the longest I have owned only one bike.
Prior USMC Sgt. and Vietnam Vet - Platoon Sgt. and D.I.
PGR Member since 2006 - Serving Those Who Served For Us.
The Native Americans found out what happens when you don't control immigration.
Mohawk is offline
post #2 of 5 (permalink) Old 11-01-2005, 02:35 AM
Eamonn1200's Avatar
Which vents are these Mohawk, the ones under the sprekers or the ones down by your shins, or is it the same process for all of them?
Eamonn.
1985 GL1200 Aspencade
Eamonn1200 is offline
post #3 of 5 (permalink) Old 11-01-2005, 04:20 AM Thread Starter
Passed On, R.I.P.
Mohawk's Avatar
Model: 09 Gl1800
I have used the process for Both.
With the detailed instructions I was thinking about the Top Vents under the speakers.
Regards,
Mohawk
Mohawk is offline
post #4 of 5 (permalink) Old 11-01-2005, 10:32 AM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
I seen the wingnut use ice-pop sticks for this and it pops (whoops a pun) the vents in a few seconds. No marks on the panels either.
Alan Fitzpatrick.
FitzAl is offline
post #5 of 5 (permalink) Old 11-02-2005, 02:17 AM
Other side of the pond
englishted's Avatar
I use one of those paint can opener tools. I covered it with insulating tape so the paint don't get marked.
Ted Kelly.
englishted is offline
GL1500 FAIRING REMOVAL TIPS jsmith Goldwing Technical Forum 4 08-29-2011 08:26 PM
Foot warmer vent cable install GL1500. Routing tips? hallfleming Goldwing Technical Forum 8 12-11-2010 07:45 PM
Dash vent removal Easy Rider Goldwing Technical Forum 5 04-25-2007 11:48 AM
Vent knob removal 98Wing-487 Goldwing Technical Forum 4 03-20-2007 09:25 PM
GL 1500 Faring Removal Tips crohnshilton Goldwing Technical Forum 13 04-02-2005 09:54 AM
