Starting reassembly - Steve Saunders Goldwing Forums
post #1 of 23 (permalink) Old 11-06-2005, 02:21 PM Thread Starter
The cleaning and painting (except for the plastic stuff) aredone and the reassembly starts. This morning I put the engine back into the repaired and repainted frame. Had to cut out and braze in a piece of steel sheet by the left swingarm mount and install a helicoil in one of holes where the upper triangular motor mount bracket bolts onto the left side of the frame.After that it was just a matter of wire brushing the frame, cleaning it with solvent priming and putting on a couple coats of gloss black enamel. Putting the engine in single handed worked okay, left the subframe off, hung the frame from the ceiling on some rope so I could ajust the height and left the engine strapped to the bike lift. It was easy to jockey the frame into placeover the engine, slip the mounting bolts in and slide on the subframe. I reassembled the driveline into the swingarm, cleaned and repacked those bearings and have the new seals in and will install the swingarm this afternoon.
post #2 of 23 (permalink) Old 11-06-2005, 02:36 PM
Hawker22's Avatar
Looks good-----Gambler started something.
Did you do much to the engine besides the obvious cosmetic stuff?
Hawker22(Ken)
Per Ardua Ad Astra
1997 GL1500SE--White Cloud
2001 GL1800----Blue Yonder
Hawker22 is offline
post #3 of 23 (permalink) Old 11-06-2005, 02:39 PM
GWEddie's Avatar
Thats some job you took on Paul, nicely sprayed frame. I hope you will keep us informed on how this goes.
Lucky Eddie.
GWEddie is offline
post #4 of 23 (permalink) Old 11-06-2005, 03:16 PM Thread Starter
No, like I said when I started, I'm not doing a full Gambler. I did a compression check looked at the plugs, tested the starter, got a set of carbs from eBay which I've cleaned and overhauled, replaced the rocker cover gaskets and timing belt gaskets and replaced the timing belts. That's about it for the engine, it was in better shape than the rest of the bike.
post #5 of 23 (permalink) Old 11-06-2005, 06:16 PM
teacher's Avatar
Year: 1983
hey paul,
It looks GREAT! I hope there are more pictures to follow?
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #6 of 23 (permalink) Old 11-06-2005, 09:16 PM
jackjohn's Avatar
It's beautiful Paul. Keep the pictures coming.
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #7 of 23 (permalink) Old 11-06-2005, 09:37 PM
TOJ
TOJ's Avatar
Hi exavid,
Looks really nice. Sure looks like you aren't the work bench varnishing type .
Tom
1985 Aspencade, cool blue
(O^O)
TOJ is offline
post #8 of 23 (permalink) Old 11-07-2005, 10:35 AM
nickpipe2's Avatar
Now let me see where did I put that thingamabobthat slides into the knipler pin? Oh yes It's in the cubby hole marked whiffler snaps.
Good luck Paul looks like a great start Keep us up to speed
1984 Gl1200 Std made over to an Aspencade, Black
1959 FLH Hydroglide
1978 Superglide
2003 Custom 124" Beast
Real men ride wearing kilts
Master Electrician, Bagpipe player and rider and wrencher of two wheel vehicles.
nickpipe2 is offline
post #9 of 23 (permalink) Old 11-07-2005, 12:58 PM
revblues's Avatar
NICE!!!!!
These rebuild threads are great. Hopefully I won't have to do anything this extensive on mine for a while, but these threads will be great reference when/if I do.
86 GL1200 Aspy
82 GL1100 Standard
"He's loadin' up his saddlebags out on the edge of wonder, one is filled with music, and the other's filled with thunder"
revblues is offline
post #10 of 23 (permalink) Old 11-07-2005, 03:05 PM
Keystone742's Avatar
Year: 1984
Model: Gl1200I
Sure does look great! Let me ask you, what paint did you use on the motor? Is there a paint code or name for it? Why enamel paint instead of base coat/clear coat on the frame?
You've got me motivated to start mine. I just have to wait until after Turkey day.
1984 1200I Candy Cobalt Blue over Bright Silver Metallic w/ Black & Silver Marbling. Poorboy alternator. Progressive springs and a comfy gel seat.
Keystone742 is offline
reassembly of starter Wilcoy02 General Motorcycle Discussion Forum 2 03-10-2012 10:02 AM
1980 Fork Reassembly Question WHEATY Goldwing Technical Forum 7 06-20-2011 04:13 PM
GL1500 Fairing Reassembly psu1 Goldwing Technical Forum 4 04-06-2011 03:54 PM
Reassembly of start switch terry_208 Goldwing Technical Forum 3 02-28-2009 10:02 PM
GL 1500 final drive reassembly wingannaprayer Goldwing Technical Forum 7 08-03-2008 01:53 PM
