'82 GL 1100 missing lower fairing tie-bar? - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 03-01-2006, 10:25 AM Thread Starter
the two halves of the lower front fairing have what appears to be a 'kinda' square hole at the bottom. Is there some sort of a tie bar supposed to link the two together? If there is, it looks like it would go right in front of the bottom part of the radiator if not touching it. I can't find any straight on pictures of the front of an '82 1100 Interstate.
\'82 GL1100 Interstate
btubb is offline
post #2 of 13 (permalink) Old 03-01-2006, 11:37 AM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
What do you mean by the lower front fairing? Are you talking about the 2 lower pieces, with the 3 vent holes, that screw to the side of the fairing, that extend down from the fairing?
The lowest part of the lowers are supposed to screw into a small L-bracket that bolts to the lower radiator. I'll find you a diagram in a second...
Look at #12 and 13 in the diagram. I think that's what you want.
Raymond
Silicon Sam is offline
post #3 of 13 (permalink) Old 03-01-2006, 11:40 AM Thread Starter
Yup... you're describing what I'm talking about. It would make sense to screw into lower radiator, as a bar across would seem to hit it. Any diagram would be appreciated. I think I'm missing the L brackets then.
btubb is offline
post #4 of 13 (permalink) Old 03-01-2006, 11:55 AM Thread Starter
That's indeed what's missing... #12, 13 and two of each: #21 & #26 (nuts & bolts??). Where exactly do they bolt onto the radiator... the front cap nuts that hold the radiator 'plate' on? Are these something available through Honda or an aftermarket or do they look like they can be fabricated without too much problem? Seems like they would need to bend a couple of ways rather than a straight "L" bracket depending on where it attaches to the radiator.
btubb is offline
post #5 of 13 (permalink) Old 03-01-2006, 12:24 PM
Here's a picture of the bracket, it wouldn't be hard to fabricate one, it's basically a ell bracket with one edge bent down. The side without the nut attaches to the lower radiator mount and the edge with the bolt is flush with the edge of the radiator screen.
post #6 of 13 (permalink) Old 03-01-2006, 01:14 PM
I have an '81 and (2) '83 Interstates, when all is said and done, one will be parts, one a Standard, and one an Interstate. You can have the brackets off one of them, if you pay for postage. Not sure if all the screws are there, but any Home Depot or Lowes will carry some metric stuff. The brackets are not all pretty and shiny like the one pictured above, but you can make do with some paint. I'll put them on my wire brush wheel before I send them.
Raymond
post #7 of 13 (permalink) Old 03-01-2006, 01:21 PM Thread Starter
Thanks Silicon Sam.. That would be great. I'll try sending you a private message.
btubb is offline
post #8 of 13 (permalink) Old 03-01-2006, 02:01 PM
teacher's Avatar
Year: 1983
Raymond
Way to go Raymond!
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #9 of 13 (permalink) Old 03-01-2006, 05:20 PM
Silicon Sam wrote:
The brackets are not all pretty and shiny like the one pictured above, but you can make do with some paint.Raymond
The pictured bracket had a long session with the wire wheel and a bit of paint, couldn't have looked much worse than yours to start. In fact all steel parts on the bike have been through that process.
post #10 of 13 (permalink) Old 03-01-2006, 08:50 PM
I've done a few pieces that way too. My horns had to be buffed and painted, for one. I even took my CI manifold to a wire wheel, till it shined, then clearcoated it. The old dingy aluminum looked sad. Pretty much during the riding season I have neglected the shiny parts and washing. I'd rather ride it then polish it, to be honest.
My frame has a few rusty areas, but that's for some other time. Maybe next Winter? After all, it was in the 80's today...
Raymond
1985 LTD lower cross over bar CWN For Sale/Wanted Forum 0 07-02-2012 01:13 PM
Ripped heim joints out of lower ladder bar?? GL1800 Trike Histicku Goldwing Technical Forum 17 10-02-2010 09:33 AM
Lower Fairing Chrome for GL-1100 redbaron Goldwing Technical Forum 5 01-13-2008 11:00 AM
GL 1100 Lower Fairing Cracks Wichita Scorpion Goldwing Technical Forum 6 11-07-2007 05:33 PM
For Sale: Upper and lower Light Bar (US - Wisconsin 77heaven For Sale/Wanted Forum 3 06-07-2007 10:16 PM
