main fuse - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 05-12-2006, 04:24 AM Thread Starter
Hippie's Avatar
I am would like to change my main fuse to the newer type did a search & didn't find anything. cold someone please tell me what type of fuse to get & maybe point me to a diagram some were?
thanks
82 interstate
1982 Interstate
Hippie is offline
post #2 of 3 (permalink) Old 05-12-2006, 05:10 AM
twisty's Avatar
thanks
82 interstate
Hippie, you need a BLADE type fuse holder with a 30 amp blade type fuse.. Use a sealed fuse holder if possible (has a snap on rubber cover)..You would like to use a fuse holder with at least 14 gaugepigtails & preferably 12 gauge pig tails..If you do a search for blade fuse then define the search to Twisty I have posted some pictures of what's needed & how to install in past posts..
Most of the better auto parts stores have those sealed blade type fuse holders as they are replacement forsome of the older GM cars & trucks..
"If there is any doubt about the condition of the red wire connector or burnt terminals at that starter relay you need to make a repair there... The best way to do that is to: cut off both large red wires just above the relay connector,, then solder the two red wires together along with one pigtail of a 30 amp sealedblade type automotive fuse holder (cover the solder joint with heat shrink tubing),, then solder a ring terminal to the other pigtail of that 30 any fuse holder & fasten that ring directly under the positive battery post screw.. That completely eliminates the relay mounted 30 amp original fuse & also eliminates any resistance down in that starter relay connection,, then put some silicone sealer in the remnants of the relay connector (where you cut the wires off) to keep any water out.. (you will no further trouble in that area after the the repair)"..
Twisty
twisty is offline
post #3 of 3 (permalink) Old 05-12-2006, 01:41 PM
SilverDave's Avatar
Model: '85 GL1200 Aspy
┬*If you search .. you can also find 40's┬* (in red)┬* I want my individual 10 to 25┬* fuses to blow first, as I find this is a fiddly fuse to access,and change ... SilverDave┬*[img]/forums/images/emoticons/emoticonsxtra/cooldj.gif[/img]
SilverDave is offline
where to get main metal fuse for your main electrical system gpmillwright Goldwing Technical Forum 21 01-21-2010 08:21 AM
Main Fuse Rod Goldwing Technical Forum 16 05-24-2009 07:11 PM
main fuse pj New Members Introduction Forum 6 07-21-2008 03:27 AM
main fuse johnsar Goldwing Technical Forum 14 01-14-2006 06:18 AM
Main Fuse LesTension Goldwing Technical Forum 3 07-18-2004 07:30 AM
