Looking for cheap head gasket/engine gasket set - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 05-31-2006, 05:17 PM Thread Starter
Hello once again, I have yet another newbie question, I have heads off of 3 goldwings, 78-81 i beleve a GL 1000, 1100 and 1200. The head gaskets all look the same, and a engine gasket kit isnt cheap, are all the head gaskets they same for these motors, if not what are the differences? I was going to buy one gasket set and fix the 1000 and 1200 if i could. Just trying to save some money, times are tuff right now. Any help will be greatly appreciated and awarded some manna thank you again Forum.
Subavettes is offline
post #2 of 5 (permalink) Old 06-01-2006, 10:07 AM
Mopar1973man's Avatar
Send a message via MSN to Mopar1973man
Honda has a head gasket kit the gives you the complete set to re-build you heads. The only seals that are NOT in the kit is the cam seals. Those you got to order separately...
It's strange but true... The valve seals are in the kit but you must remove the cam to change the valve seal so why isn't the cam seals in the kit???
I just got done doing a head gasket on my wing... Not very expensive... about $170 bucks for the gasket kit.
1983 Goldwing Interstate GL1100I
BOMB! (Better Off Modified Baby!) - MP3 Player, Fan Bypass Switch, Homemade Trailer
Mopar1973man is offline
post #3 of 5 (permalink) Old 06-02-2006, 09:05 PM
why me?'s Avatar
Try www.siriusconinc.com their prices are the best I've found and their kits are great quality. Good luck, Bob
Bob, why me? cross? 1981 gl1100 standard
why me? is offline
post #4 of 5 (permalink) Old 06-02-2006, 10:21 PM
Geek's Avatar
bikebandit.com has some good prices as well.
76 GL1000
Soul Zone Motorcycle Riders
Secretary/Treasure
When I got my computer it said "For MS Windows 98 or better", so I installed LINUX.
Geek is offline
post #5 of 5 (permalink) Old 06-03-2006, 09:39 AM
why me?'s Avatar
Hello again, for parts you havegl1000 and gl1100's the gl1000 were made from 1975 to 1979 and the gl1100's were made from 1980 to 1983. Good luck, Bob
why me? is offline
Gl1200 Head Gasket...Gasket problems rttoy Goldwing Technical Forum 26 12-30-2015 12:57 PM
How to set timing belts after a head gasket job? Tom2 Goldwing Technical Forum 14 07-13-2010 06:01 PM
Best aftermarket gasket kit for GL1100 head gasket job? Tom2 Goldwing Technical Forum 4 07-06-2010 01:20 PM
gl1200 head gasket set rplg General Motorcycle Discussion Forum 4 03-03-2010 02:38 PM
Need engine gasket set for 84 Goldwing Interstate jakerpooch Goldwing Technical Forum 2 04-05-2007 11:30 PM
