no dash lights...bad ignition switch? - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 06-09-2006, 06:54 PM Thread Starter
JAinPA's Avatar
hello all,
OK...today I was not able to start my bike.
The Problem: This morning on the way to work I stopped at a store and had to "jiggle" the key to get my dash lights on and get the bike started.
At quitting time I was not able to start it at all.
The Symptoms: Seems to be weak contact in the ignition switch. Radio does not come on at "ACC" position (it should). It comes on at "ON" position but can be killed be wiggling the key a bit. I get no dash lights and no headlight. I get no lights in the "PARK" position.
Am I correct in assuming the problem is a bad ignition switch? Or could it be something else?
All ideas will be appreciated.
Thanks,
Jim
\'81 GL1100I
So much fun on two wheels!
JAinPA is offline
post #2 of 8 (permalink) Old 06-09-2006, 08:13 PM
wda-83wing's Avatar
Model: 83 GL 1100 I
if i had to guess i would say ing. switch. if it`s on a 1100 anyway.
wda-83wing is offline
post #3 of 8 (permalink) Old 06-09-2006, 08:27 PM
dirt's Avatar
Yes, it more than likely is the ignition switch. My GL1100 did the same thing. Someone noticed how many keys were hanging from the switch and made the statement that a lot of keys will ruin the tumbler in the switch. Ever since, only the bike key goes into the ignition. This applies to cars as well. Hope you find the problem are are able to correct it real soon. The best of luck to you.
Dirt
Ride smart and safe
dirt is offline
post #4 of 8 (permalink) Old 06-09-2006, 09:16 PM Thread Starter
JAinPA's Avatar
thanks guys,
should the entire switch be replaced or can I get by with replacing the switch back?
\'81 GL1100I
JAinPA is offline
post #5 of 8 (permalink) Old 06-09-2006, 09:28 PM
wda-83wing's Avatar
Model: 83 GL 1100 I
best bet to replce the switch complete. it will come with new key`s ,new wire and connector. you will have to take the fairing off to get to the wireing underneth the counter wieght. it`s an morning job.
post #6 of 8 (permalink) Old 06-09-2006, 09:45 PM
dirt's Avatar
Can not remember if I had to take the complete fairing off or not. Doesn't seem like I did but not for sure. It seems if you are good at bending your arm and hand you can get by without doing so. Remember to keep your old set of keys around as you will need it to unlock your gas tank. Good luck.
Dirt
Ride smart and safe
dirt is offline
post #7 of 8 (permalink) Old 06-13-2006, 07:26 PM
wda-83wing's Avatar
Model: 83 GL 1100 I
well what was the out come?? was it the ING. switch? or wasit the main fuse??
post #8 of 8 (permalink) Old 06-13-2006, 08:02 PM
dirt's Avatar
On mine it was the switch. The tumblers had gone bad and once the switch was replaced then everything worked fine.
Dirt
Ride smart and safe
dirt is offline
GL1100 dash gauge lights, self cancelling switch went out same time big daddy Goldwing Technical Forum 3 05-17-2012 07:08 PM
GL1500 lost gauges, tail lights, reverse and some dash lights creamer725 Goldwing Technical Forum 4 07-05-2011 05:52 PM
Intermittent no ignition or dash lights pmuscutt Goldwing Technical Forum 1 09-04-2007 01:36 PM
Loss Of Running Lights, Dash Lights-Blown Fuses 1964 Interstate dean Goldwing Technical Forum 5 04-03-2007 01:01 PM
Bad Ignition Switch Wingin It Gene Goldwing Technical Forum 5 07-25-2005 12:11 PM
