GL 1200 Factory Cruise Control Problem SOLVED! - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 06-24-2006, 08:21 AM Thread Starter
NDAV8R's Avatar
Year: 1995
Make: Gl1500
Hi Gang!
A few weeks ago I wrote in if anyone had any ideas on what could be wrong with my Factory Cruise Control on my '87 Aspencade. The problem was, after it was set, the speed would drop about a mph every 5 seconds or so.
I used a vacuum hand pump to check the actuator, acummulator, and control with all of them holding vacuum. I took advise to check all electrical connectors-OK. I checked voltages at the controller and individually fired the 3 solenoids-OK. Man...what could it be? I purchased a complete cruise set up less the computer on ebay-$25(oh well) thinking it could be acummulating problem from all total components...WRONG! Still had the same problem! The problem seemed to be pointing at the computer (another $60 to $80 on ebay-NUTS). But before I committed to buy a computer, or buying an aftermarket cruise, I went to check my source vacuum from the engine.
What appeared to be a normal looking vacuum line right off the vacuum tee of the left rear cylinder, was a small 1/2" of rubber vacuum line that stayed collapsed when I squeezed it. It was very musshy in feeling and was at the low dip(probably where crankcase vapors condensed and left laying there eating away at the rubber hose. I cut off the bad spot, and temporary hooked it back up to the tee, until I replace the whole line.
Now, it works perfect! My numb throttle fingers thank me and scolded me for not Keeping It Simple Stupid! Thanks for all the great suggestions, tips, and advise!
Gale Hansen.
Gale Hansen
Aviation Upholsterer and Tig Welder
CANCER SURVIVOR
1987 GL1200
1976 KZ900
1975 Yamaha 175 Trials
1975 Honda XL 350
1961 Cushman Scooter
1946 Cushman Scooter
NDAV8R is offline
post #2 of 2 (permalink) Old 06-24-2006, 08:58 AM
Ruaidh's Avatar
Model: '02 1800
Send a message via Yahoo to Ruaidh
Isn't it nice when it's a simple solution?
Ruaidh
To know what is right and not act accordingly is the worst cowardice. - Confucius
Words, unwritten, have no value. - Caius Merlinus Brittanicus
Yellow '02 1800
Ruaidh is offline
Cruise control problem solved, GL1500 NevadaDave Goldwing Technical Forum 6 10-03-2012 08:02 PM
GL 1500 Cruise Control Problem Solved jacksrwild Goldwing Technical Forum 4 08-29-2012 06:47 PM
GL1200 Factory Cruise Problem NJWingleader Goldwing Technical Forum 11 04-07-2011 09:35 PM
How do I install a factory cruise control I purchased for my GL1200? randywhet Goldwing Technical Forum 11 03-11-2011 01:10 PM
Cruise Control Problem ! Robert1984 Goldwing Technical Forum 12 07-12-2008 07:42 PM
