tightening rear view mirror swivels? - Steve Saunders Goldwing Forums
post #1 of 29 (permalink) Old 07-12-2006, 11:39 AM Thread Starter
Year: 1982
Make: Goldwing
Model: Interstate
Hey all...
Just wondering if anyone knows if it's possible to tighten up the swivel joints of the rear view mirrors on my bike? They seem to be loose enough so when I go over anything jarring on the bike, they move out of position. Maybe I'll have to spring for a new set if they can't be tightened...
Thanks
"Give me some wings I can glide upon" - Gordon Lightfoot
Bikes from previous lives...
1976 CJ360-T
1978 CX500
In Process...
1982 CX500 Custom
"Live Free or Die: Death is not the worst of evils" -General John Stark-
Timmus is offline
post #2 of 29 (permalink) Old 07-12-2006, 11:54 AM
I have the same problem with my bike. I took off the mirror and undernieth is a nut and heavy spring. I tightened the nut putting more pressure on the spring and believe it is better. May try it again as they still move with a high wind. I was afraid to tighten too much for fear of breaking something.
Don Defoort
1998 1500 se.
DoDefoort is offline
post #3 of 29 (permalink) Old 07-12-2006, 12:38 PM
I had a similar problem with my 1200, at highway speed the left mirror would blow down from where I set it. I finally got fed up, stopped at a convenience store got some crazy glue and dropped a bit in the ball and socket joint after I readjusted the mirror. Never moved again.
post #4 of 29 (permalink) Old 07-12-2006, 04:21 PM
Burleyman88's Avatar
Send a message via Yahoo to Burleyman88
Me too. The nut sits against a spring inside, and I dont think you have to worry too much about overtightening it.....it's pretty stiff......just don't go crazy with it. I've got mine to where they are very very stable, so havent had to use the crazy glue approach....I don't think I'd want to use the glue; sometimes I feel like readjusting it depending on what kind of terrain I'm riding in. Bman
Wind in the hair is good for the soul. Bman
1982 GL1100Interstate - Former Ride.
2000 Valkyrie Interstate - Current Ride.
Burleyman88 is offline
post #5 of 29 (permalink) Old 07-12-2006, 05:21 PM Thread Starter
Year: 1982
Make: Goldwing
Model: Interstate
Thanks for the suggestions....i will try the "tighten the nut" routine first. If that doesn't do the trick, I may need to resort to more radical measures but probably not as radical as exavids solution...in the end, I just may end up buying a new set...they are still available and not as pricey as one might think.
1976 CJ360-T
1978 CX500
In Process...
1982 CX500 Custom
Timmus is offline
post #6 of 29 (permalink) Old 07-12-2006, 06:40 PM
Exavid,s approach with super glue was not radical, I drilled a hole in the ball joint and put in a sheet metal screw. Now thats radical!
Alski [ Lord, please make me as good as my dog thinks I am!]
1987 Aspencade - Black
alski425 is offline
post #7 of 29 (permalink) Old 07-12-2006, 08:24 PM Thread Starter
Year: 1982
Make: Goldwing
Model: Interstate
You are indeed correct...exavid's solution seems pedestrian to yours...
1976 CJ360-T
1978 CX500
In Process...
1982 CX500 Custom
Timmus is offline
post #8 of 29 (permalink) Old 07-12-2006, 09:59 PM
Hobie1's Avatar
I thought about taking my 83I's mirror assemblies apart and use a slow setting silicone compound in the ball socket. I wouldalign my mirrorsto where I want them to be. The silicone wouldset up andthen the mirrors shouldn't move but could be moved if need be.
What do you guys think?
Hobie
Mark
Wineberry 1983 Interstate
Hobie1 is offline
post #9 of 29 (permalink) Old 07-12-2006, 10:14 PM
Not only radical, but damned creative and permanent!!!
post #10 of 29 (permalink) Old 07-12-2006, 10:16 PM
Hobie.....I found a new used mirror on here a while ago...my one mirror was rusty inside. Got it for 10$ plus shipping. You can prob find one on here somewhere if you're willing to wait. I wonder if the silicone will be actually strong enough to keep the mirror from moving. Guess you could try it. Not that radical.... Bman
New Tech Tip: Correct Rear End Tightening Sequence petevenne Goldwing Technical Forum 1 11-10-2010 08:46 PM
Tightening a loose GL1800 mirror Comanche Goldwing Technical Forum 5 06-26-2010 10:10 PM
Need Help 83 1100. Rear wheel binds when tightening axle nut. Jerryk Goldwing Technical Forum 3 10-01-2009 06:41 AM
Right Rear View Mirror GL1800 Hodgo For Sale/Wanted Forum 3 06-26-2007 10:28 AM
gl1800 Parts Breakdown for Rear View Mirror White Lightning General Motorcycle Discussion Forum 1 06-21-2007 11:21 AM
