96 1500 SE Starter spinning issue - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 07-24-2006, 05:28 PM Thread Starter
I have a 1996 1500 SE and recently the starter has begun spinning for no apparent reason. You can hear it spin when the engine is running and when you shut the engine down it still spins. It will stop if you hit the starter button a couple of times.
The starter has also begun to have issues of not working at all when the bike is in gear and the kickstand is up. This is an intermittent problem, not continuously. It will always work correctly if the bike is in neutral.
Any thoughts on if this is a reverse switch problem or actually related to the starter itself.
wingcrazy is offline
post #2 of 4 (permalink) Old 07-25-2006, 02:45 AM
wexy's Avatar
Year: 2003
It is your starter button sticking ,,Put some wd 40 into the button and work the button in and out ,There is a spring in there and it may be corroded ,,If that does not work check the relay ,it may be sticking ,,But it sounds more like starter button not releasing ,,cheers Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #3 of 4 (permalink) Old 07-25-2006, 04:44 AM
GoWing's Avatar
These starterbuttons do stick, often when you are reversing. It's fun sitting on a runaway reversing 1500 when it does happen!
Larry.
GoWing is offline
post #4 of 4 (permalink) Old 07-25-2006, 05:42 PM
wingnut's Avatar
Send a message via Skype™ to wingnut
WD40 doesn't always work either as the starter switch is sealed well. Try it and see, but you may have to open up the switch.
Steve Saunders,
Founder Member & Admin.
wingnut is offline
82 gl 1100 starter spinning nlc302 Goldwing Technical Forum 5 01-26-2012 10:43 PM
85 aspencade starter spinning justwannaride Goldwing Technical Forum 62 12-14-2010 11:14 PM
GL1200 spinning starter PUDGYHD Goldwing Technical Forum 6 12-04-2010 10:47 PM
free spinning starter alwing Goldwing Technical Forum 5 04-13-2009 08:23 PM
starter spinning glassman Goldwing Technical Forum 3 04-06-2006 12:28 AM
