4th gear thump, GL1500 - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 10-14-2006, 10:15 AM Thread Starter
Ruaidh's Avatar
Model: '02 1800
Send a message via Yahoo to Ruaidh
I have noticed on my '90 1500 that when I am in 4th gear coasting and I roll on the throttle, it feels like the bike is taking up slack out of the drive shaft or rear differential. I cannot duplicate this in any other gear; it only occurs in 4th gear. For example, if I am riding in 4th gearand traffic slows I let off the throttle. As I accelerate, I feel a little "thump" from the drive train.
I thought that there was a previous thread on this but I cannot find it. I'm not stressing about this; it doesn't feel strong enough that it's causing a problem it is just that with the smooth riding bikes, you notice things like this.
Ruaidh
To know what is right and not act accordingly is the worst cowardice. - Confucius
Words, unwritten, have no value. - Caius Merlinus Brittanicus
Yellow '02 1800
Ruaidh is offline
post #2 of 10 (permalink) Old 10-14-2006, 10:25 PM
fatalattraction's Avatar
I don't have an answer for you, and this will put you back to the top but I'm willing to bet that to fix it you have to pull the seat.
Now in limbo trying to decide what I want to get.
fatalattraction is offline
post #3 of 10 (permalink) Old 10-16-2006, 08:19 AM Thread Starter
Ruaidh's Avatar
Model: '02 1800
hehehe
Yeah, I have no doubt.
Yellow '02 1800
Ruaidh is offline
post #4 of 10 (permalink) Old 07-07-2009, 06:35 PM
marknewbill's Avatar
i feel it on mine in 4th and 5th , really any gear. im so glad to find at least one person who has felt this.
all i have to do is go about 45 mph in 5th and gently roll off the throttle and i feel a light bumping in the forward pegs, and if i roll off completly, and rol on i feel it as one thump, i think exactly as you said. will do in 4th as well. a little in third and not noticable anymore in lower gears.
'maybe normal??
did you ever find a cause or just keep on riding it?
Just my 1.99 cents
Mark Newbill
marknewbill is offline
post #5 of 10 (permalink) Old 01-29-2010, 07:30 PM
fixed this later on by replacing the u-joint. couldnt see what the problem was as it looked fine, but the used one from ebay stopped 90 percent of the slack feeling. just thought I would update this in case it helps somebody else.
Just my 1.99 cents
Mark Newbill
post #6 of 10 (permalink) Old 01-29-2010, 09:08 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Hope it is something simple. A couple of places to check might be the rubber dampners inside the rear wheel that absorb shock from shifting. Might pull the drive shaft out and check the front and rear splines. How is the rubber boot over the front of driveshaft? If it is gone, might lead to the U joint failure.
Tom Bishop
98` S.E.
gumbyred is offline
post #7 of 10 (permalink) Old 01-30-2010, 05:51 AM
Monkey with a Football
Rudy's Avatar
There is some freeplay in the drive line. I doubt it's something to be concerned about. Mine seems like an inch or two at the wheel.
But it doesn't hurt to look at the U-Joints, the drive shaft splines, the rear drive and the rear wheel splines and dampener as has already been mentioned. If you haven't been in there in a while, it's as good a time as any to do so and moly paste those splines.
Rudy
wasn't too much fun”
Rudy is offline
post #8 of 10 (permalink) Old 01-30-2010, 07:55 AM
Senior Guru
agnogel's Avatar
i had the same prob in 4th gear only lasted a couple of months then the dreded 4th gear selector fork rattle kicked in after that engine out split in two 2,000euro fixed
Peter
agnogel is offline
post #9 of 10 (permalink) Old 01-30-2010, 08:18 AM
gumbyred's Avatar
Like I said. I hope its something simple. Just before the transmission gave up on my old `91 Aspencade, it would have a strange lurch when downshifting from 5th, to 4th. You don`t mention if you have floorboards, with a heel/toe shifter.
Tom Bishop
`98 S.E.
gumbyred is offline
post #10 of 10 (permalink) Old 01-30-2010, 09:43 AM
so what is the dreaded 4th gear selector rattle you mention? what does that sound / feel like and when do you notice it? is it something you feel in the shifter or what exactly? and what year bike was this on, i heard some years had problems with 4th and an "improvement was made"
Just my 1.99 cents
Mark Newbill
GL1500 4th gear bull463 Goldwing Technical Forum 1 04-06-2012 07:21 AM
GL1500 Noisy 4th gear Lindeman Goldwing Technical Forum 11 03-17-2012 08:27 AM
GL1500 4th gear fix Jim_C Goldwing Technical Forum 8 06-22-2011 02:59 PM
GL1500 4th gear repair wingnut Goldwing Technical Forum 9 12-02-2010 04:18 PM
GL1500 4th Gear bobrobert Goldwing Technical Forum 3 05-30-2006 06:15 PM
