Heated Clothing install question on a 1500 - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 10-19-2006, 07:39 AM Thread Starter
Bigdave's Avatar
In order to extend my riding season, I just purchased Gerbings jacket liner and gloves. Now I have to install the controller (dual) on the bike. I got the permanent type so that I can hide the wires as much as possible.
If anyone has installed any type of controller on their bike, where did you positiion the control knobs?
Where did you route the wires the jacket plugs into?
Did you have any wiring problems?
Any suggestions appreciated - especially pictures!
Dave
Beautiful Teal \'93 SE
Bigdave is offline
post #2 of 2 (permalink) Old 10-19-2006, 12:42 PM
Best looking member
Goldwinger's Avatar
Make: Honda, is there any other?
Model: 1997 SE. Pearl Green
I was looking to install some switches on my 97 SE and the only place I could think of was on the right side above the compressor controls. You would have to move the vacuum valves behind that spot depending on the size of the controller. You can't use the other side above the CB as the mounting bracket for the CB takes up all the space.The left side isbest if possible as you can adjustthe heat on the fly without havingtoengage the cruise. I never did use that spot as I opted for replacing the key surround with a aftermarket unit that allowed me to install a volt meter and room for some switches. Just a thought. Good Luck
Pearl Green(The Intelligent colour)
No question A.T.G.A.T.T. (Even when it's stinking hot!!)
And if it's too stinking hot to gear up, it's too stinking hot to ride.
If your not man enough to take the lead, stop complaining from behind.
I SURVIVED NASSIR 9.... barely.
To all of the troops and Vets. Thank you. I will never forget.
A proud Wild Rhino(Ontario) since 18 Jul 2013 (That mating sound thing really works!!)
Goldwinger is offline
Heated Clothing bagelboy General Motorcycle Discussion Forum 26 10-15-2010 10:25 PM
Heated Clothing Texaswinger50 General Motorcycle Discussion Forum 7 09-20-2010 12:34 AM
Heated clothing foxtrot5 General Motorcycle Discussion Forum 20 01-09-2009 08:13 AM
Heated clothing Redrider23 For Sale/Wanted Forum 2 01-08-2009 12:57 PM
Heated Clothing wilkoi General Motorcycle Discussion Forum 4 12-17-2008 07:04 AM
