Front Forks - Adding Air - 1200GL - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 12-03-2006, 01:35 PM Thread Starter
Sly
Sly's Avatar
The manual for my '86GL Interstate says to remove the caps and fill both forks with air. The fork on the brake side of the bike has a cap and air inlet which I filled to 6 psi. On the clutch side, there is the same little cap but it does not have an air inlet.
Is this normal or has someone replaced the air inlet with something non-stock?
Thanks for answering a very simple question.
\'86 GL - Interstate
Ride to Live... and vice versa
Sly is offline
post #2 of 4 (permalink) Old 12-03-2006, 01:38 PM
Model: Goldwing
You are not missing anything there is an air equalizer Assembly between them with only one air valve for both
ccsailor is offline
post #3 of 4 (permalink) Old 12-03-2006, 01:40 PM
Shooter's Avatar
Model: 2006 ST 1300
There is a chrome valve stem type cap on the right side(front brake) of the fork on my 86 Interstate. Never recall seeing anything on the left. Then again, I never really looked.
1986 Interstate, 2006 ST 1300
Shooter is offline
post #4 of 4 (permalink) Old 12-03-2006, 01:47 PM Thread Starter
Sly
Sly's Avatar
Thanks guys
Sly is offline
Adding air to GL1200 front forks after rebuild? lookin4fish Goldwing Technical Forum 7 04-07-2011 10:33 PM
GL1200, adding air to front forks after rebuild lookin4fish Goldwing Technical Forum 1 04-07-2011 09:29 AM
Front Forks air pressure mjohnson Goldwing Technical Forum 4 01-03-2007 02:02 PM
AIR IN FRONT FORKS RUDOLPHD Goldwing Technical Forum 2 04-04-2006 07:52 PM
front forks and air pressure johnsar Goldwing Technical Forum 21 12-30-2005 04:03 PM
