Speed pickup noise in Audio system. - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 01-02-2007, 07:08 AM Thread Starter
Cruzan1984's Avatar
Has anyone heard of this problem before?
The pulse generated by the speed sensor on the front wheel is carrying (Bleeding) over into the Audio system on my 84 Aspencade. It sounds like a whine at speed but slows to a pop...pop as speed decreases.
I suspectI may need to install a filter but not sure what has caused it. I can see by the schematic that there could already be a filter installed although it was an option and I haven't confirmed it's existance as yet.
Thanks, Cruzan
Cruzan1984 is offline
post #2 of 12 (permalink) Old 01-02-2007, 09:53 AM
wexy's Avatar
Year: 2003
Yep it sounds like a surpressor(filter) either missing or gone bad ,,If it has only come into it ,then I would suspect a filter gone bad ,Also check all the grounds are clean and tight ,,Cheers Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #3 of 12 (permalink) Old 01-02-2007, 11:58 AM
gkiesel's Avatar
Send a message via MSN to gkiesel
Cruzan, My 84 does the same thing!, the faster i go the more it turns into a wine type of sound. Funny thing is there is no noise through the headset, only through the speakers. I have never been able to track down the source. It seems to have started after I installed the EC harness. But I could be mistaken. Thanks for letting me know I'm not the only one. George.
George K
1984 Aspencade
1999 Kawasaki zrx1100
1995 Honda CR250
1977 KZ400 S3
gkiesel is offline
post #4 of 12 (permalink) Old 01-02-2007, 12:04 PM
Monkey with a Football
Rudy's Avatar
Don't know if it would help or if you can but have you tried re-routing the EC harness around into different positions to see if it makes it better or worse?
Rudy
wasn't too much fun”
Rudy is offline
post #5 of 12 (permalink) Old 01-02-2007, 12:15 PM
Senior Guru
Oregonwinger's Avatar
The speedo encoder is such a low level signal, it seems unlikely to contribute to radio noise. I see no supressor/condensor in the schematic. I know that regulator switching can get into the radio signal. Are you saying you get the noise at wheel speed, no matter what gear you're in? Confirm whether it is related to engine rpm, and if it is, try cleaning up as many grounds as you can find. That ground at the triangle engine mount, is suspect, as well as the grounds at regulator. Sounds like a "ground loop" problem. Might refresh the radio contacts at back of radio, also.
BOB
Oregonwinger is offline
post #6 of 12 (permalink) Old 01-02-2007, 01:29 PM Thread Starter
Cruzan1984's Avatar
Noise is definately generated by wheel speed as I can duplicate it by spinning the wheel by hand with the engine off. I will check the EC Harness routing and confirm good grounds. Thanks all
post #7 of 12 (permalink) Old 01-02-2007, 01:45 PM
gkiesel's Avatar
Yes definitely wheel speed here too. With engine off, rolling down a hill, the noise changes speed and pitch the faster the machine rolls and goes to zero coming to a stop.
George K
1984 Aspencade
1995 Honda CR250
1977 KZ400 S3
gkiesel is offline
post #8 of 12 (permalink) Old 01-02-2007, 02:25 PM
Senior Guru
Could actually be eminating in speod cluster, after it's amplified. Keep us posted. My last 2 digital dashes didn't do that at all, but I didn't do the EC harness. Must be related to that, it seems.
BOB
post #9 of 12 (permalink) Old 01-23-2007, 10:21 AM
Ed
edgin1601's Avatar
Model: GL1200A
Send a message via Skype™ to edgin1601
Had a problem as such and it was the antenna, I had unscrewed it and when I put it on again I had that problem. Redone the antanna and it quit
IF you Can\'t afford a Doctor, go to an airport-you\'ll get a free X-ray and breast exam, and; if you mention Al Qaeda you\'ll get a free colonoscopy.
edgin1601 is offline
post #10 of 12 (permalink) Old 05-17-2007, 12:18 PM Thread Starter
Cruzan1984's Avatar
Thanks for the help.
I checked the antenna connections and found that there was some rust in the folding joint. Cleaned it and replaced thejoint fastener.Everything seems fine. That will sure make the audio more enjoyable.
Safe Cruzan
1200 audio system EDDIE W General Motorcycle Discussion Forum 9 05-11-2010 05:10 AM
Audio system help dwvassar Goldwing Technical Forum 2 03-09-2008 08:15 AM
gl1100 audio system Scooter 7 Goldwing Technical Forum 8 05-29-2007 06:40 AM
UPGRADE THE AUDIO SYSTEM jukeboxjury123 Goldwing Technical Forum 6 09-05-2006 11:36 AM
wiring diagram for audio system bigdogrod Goldwing Technical Forum 9 04-19-2006 06:43 PM
