Another gear ratio question - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 01-20-2007, 07:07 PM Thread Starter
dan filipi's Avatar
Model: 1983 GL 1100 I
Is a rear end ratio of 411 "lower" than 383?
That is, say in first gear, does 411 give you more axle twisting torque and turn the engine faster at a given road speed than 383?
dan filipi is offline
post #2 of 10 (permalink) Old 01-20-2007, 07:11 PM
You are right with the first guess.
4:11 means the crankshaft makes 4.11 revolutions to 1 revolution of the rear (driven) wheel.
Therefore, it would provide more torque than the 3.83 ratio because the engine is turning slower for the same rear wheel speed.
What is the Forum Index?
Download it here:
post #3 of 10 (permalink) Old 01-20-2007, 07:48 PM Thread Starter
dan filipi's Avatar
Thanks AZ
post #4 of 10 (permalink) Old 01-20-2007, 07:51 PM
Unless you're backing up!
[suB]Sorry, couldn't resist that.[/suB]
post #5 of 10 (permalink) Old 10-02-2011, 09:00 PM
icu2's Avatar
Good question and some good answers. Now I have a question. I have a Goldwing Trike 1800, 2005,with a Chamption kit. I'm sure I have a Toyota rear end, but I want a higher gear ratio. What model has got a higher ratio rear end?
icu2 is offline
post #6 of 10 (permalink) Old 10-02-2011, 10:21 PM
SidecarMike's Avatar
Year: 1996
Make: Aspencade
Model: 1996 Aspencade with a Friendship 3 sidecar & 1997 Valkyrie
Your best bet might be to take it to a Toyota dealership and see if they can identify it. If so, there may be other ratios available by changing the gears inside your housing. For example, my '64 Impala had 5 different ratios available from 3.08 to 4.56 depending on engine size, type of carburetion, and whether the trans was auto or manual shift.
You may find the same to be true with yours.
SidecarMike
A motorcycle is like a cast iron skillet, it mellows with age, wash it and you destroy years of seasoning!
The Mistress, 1996 Aspencade & Sidecar 1997 Valkyrie, the Borderline Outlaw
SidecarMike is offline
post #7 of 10 (permalink) Old 10-02-2011, 10:26 PM
It aint rocket science
DriverRider's Avatar
Model: The best
There should be a tag, usually on the differential cover that will give the ring gear size and axle ratio. This for US built cars for sure.
JD
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #8 of 10 (permalink) Old 10-02-2011, 10:38 PM
Hey icu2
What do you mean by higher ratio. Are you looking to raise or drop the engine speed at a given roadspeed. When talking axle ratio's a higher ratio usually means more engine rpm and more power touqe. A lower ratio numericaly gives more speed and less power much like an OD would
Wilf
79 gl1000 dresser
80 gl1100I now naked
90 1500 full dress
wilf is offline
post #9 of 10 (permalink) Old 10-03-2011, 06:11 AM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Larger number = lower gear ratio = higher RPM
as an example I just was researching this to buy tires for my sons truck .
ratio 4.11:1 , 35" tire [email protected] 55MPH = 1520 ( in overdrive )
ratio 3.42:1 , 35" tire [email protected] 55MPH = 1265 ( in overdrive )
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
post #10 of 10 (permalink) Old 10-03-2011, 10:39 PM
icu2's Avatar
Ok, a lower ratio. I knew I was going to get that wrong!! I'm wanting to lower my RPM, just a little without causeing a strain on the 1800. Right now, at 70 MPH I'm turning about 3,000 RPM. I want to drop about 500 RPM. If I drop 1,000 RPMs, it'll be too much. I have high loop torq pipes, true duel exhaust, let's say, better muffers, so I'm not lacking for power or torq by doing this. Speed is not the purpose for doing this. We put between 40,000 and 50,000 miles a year on the 1800. I just want a little better mileage and I know the Wing is fully capable of this change, or at least I believe it is.
icu2 is offline
Gear Ratio difference 81-82 Rumple Goldwing Technical Forum 12 03-19-2012 12:40 AM
Gear ratio Nightrider1 Goldwing Technical Forum 12 11-11-2010 11:22 AM
gear ratio skoto1 Goldwing Technical Forum 16 05-14-2009 11:38 PM
1800 gear ratio kenracer Goldwing Technical Forum 2 09-22-2008 10:26 AM
Gear ratio question dan filipi Goldwing Technical Forum 6 10-26-2006 12:00 PM
