front forks gw 1200 - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 02-26-2007, 02:58 PM Thread Starter
hi replacing my front fork seals. i removed easily my 1st 6mm allen bolt from the bottom of the 1st fork. the 2nd fork, the allen bolt. came loose easily but it is spinning
inside of the fork itself not allowing me to remove the tube how can i remove the
inside bolt/fastner and what wrench tools are required any help on this..
thanks much
scot
scot is offline
post #2 of 10 (permalink) Old 02-26-2007, 03:21 PM
Is there anyway you can use an air wrench?
87 GL1200I Grey
03 GL1800 Red
wingmaster is offline
post #3 of 10 (permalink) Old 02-26-2007, 04:07 PM
Snorebaby's Avatar
2 questions......Are the forks still on the bike? Have you removed the springs?
'15 GL1800 Scarlett
'90 GL 1500 SE Pearl
'86 CMX450 Rebel
'85 GL1200 LTD---SOLD
Patriot Guard Riders #137660
Snorebaby is offline
post #4 of 10 (permalink) Old 02-26-2007, 04:36 PM Thread Starter
forks off the bike and have used an air wrench to remove to remove the allen bolts.
and springs removed.
scot is offline
post #5 of 10 (permalink) Old 02-26-2007, 04:39 PM
Wendell's Avatar
If I am reading this correctly, It sounds like the tube inside is turning too. I have read here where one has used a broom handle pushed down inside to hold it in place while the allen bolt is loosened. Another way, as mentioned by wingmaster, is the air gun. Using an allen socket attached to your air gun (make sure is is a good gun) try to back it out QUICKLY. Mine did the same thing and came out the rest of the way with this method. If it does not, change direction on the gun and try to snug it back up, then run in out QUICKLY again. That should get it out. One more thing, make sure the gun is straight and the allen wrench is seated completely in the bolt beforehand. Otherwise, you'll round it out! Wendell
Wendell is offline
post #6 of 10 (permalink) Old 02-26-2007, 04:41 PM
Wendell's Avatar
oops....guess I was a little slow on the draw!
Excellent job scot! Good Job!
Wendell
Wendell is offline
post #7 of 10 (permalink) Old 02-27-2007, 07:03 AM
Passed On, R.I.P.
welsh winger's Avatar
I had this a few years ago and used a broom handle, with the end turned down, placed it in the tube give it a tap with a hammer and it should hold the inside parts still while you release the bolt, you may need a second pair of hands to hold things and best check there are no wood spinters before you reassemble.
Nick
Welsh Winger
1982 1100DC 38,000 miles
Nick Duffy (Welsh Winger) is no longer with us. He passed away in mid-September 2012, joining his wife Julie in Paradise.
welsh winger is offline
post #8 of 10 (permalink) Old 02-27-2007, 05:21 PM
Cal-D's Avatar
Model: Stream Silver 2007
scott
re-install the spring and cap, this will apply some pressure to the rod and allow you to remove the allen bolt. If it still spins, probably someone used lock tight on it before. If that is the case lock the lower in a vise and have someone try to pull on the slider, as if pulling the slider out of the lower. This will apply more force to hold the rod. Should only remove the spring after the lower bolt is out.
Have Wing Will Travel
Cal-D is offline
post #9 of 10 (permalink) Old 02-27-2007, 05:24 PM
ScottInNV's Avatar
Model: 76 GL1000
Cal-D wrote:
scott
+1, this is how i get my lower bolts out. the spring pressure is normally plenty to avoid the parts turning, and there is no chance of getting splinters where they are definitely not wanted
1976 GL1000 Nekkid!!
formerly had
1980 CX500
1981 GL500 SilverWing
1985 Honda GL1200 LTD
ScottInNV is offline
post #10 of 10 (permalink) Old 02-27-2007, 07:19 PM Thread Starter
hi did that and it worked.. live and learn. unscrew the lower end 1st.
scot is offline
GL-1200 Front Forks to RaceTech rgbeard Goldwing Technical Forum 5 06-04-2010 11:06 AM
Wanted 1200 front forks john chater For Sale/Wanted Forum 7 04-28-2006 03:34 AM
1200 front forks wanted. john chater For Sale/Wanted Forum 3 03-30-2006 07:47 PM
Wanted front forks for 1200 john chater For Sale/Wanted Forum 4 02-09-2006 08:26 PM
info on front forks for 1200 john chater Goldwing Technical Forum 6 10-17-2005 03:12 PM
