Help! - I've got oil in my gas -or- gas in my oil!?! - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 03-30-2007, 11:26 PM Thread Starter
Hi Everyone - I've been away from the forum for most of the winter due to some tough family challanges and I've been starting up a new business... things have settled down now, and the business is going pretty well. Spring is here and so is the bug to get outdoors and start riding again. Here's my problem...
Through the spring, summer and fall of last year I was working at restoring an 83' Aspencade that I had taken in as payment on a job that I couldn't collect on otherwise - the bike had been sitting unridden for 10 to 12 years with gas in the tank, bald tires, dry-rotted rubber, and all of the rest. I took my time and went through most of it, replacing or repairing as needed and money allowed. All the while getting a great motorcycle eduction on this fine forum.
I'm no expert - but with confidence gained from you guys and your expertise, I undertook a full carburetor rebuild, it all seemed to go really well, and so with shiney new parts and everything cleaned and looking spiffy, I put gas in the tank and hit the starter (Old, original starter that is) nothin happened. I went to pull the starter a couple of days later and when I did... gas came running out of the starter opening! Seems one of the floats was stuck and gas had been running down into the cylinders and into the case.
It was sort of the last straw for me then - the cold weather was already here and my funds were pretty much gone - so in frustration I stuck the starter back in it's place, shut off the petcock and stuck the bike out in the shed for the winter - Now, with the warmer weather I've decided to have another go at the goldwing. I'vebought good new carbs ready to install, a new starter ready to install, but of course (and yes, I know, I should have thought of this long ago), when I opened the oil drainplug last week,all of the oil mixed now with gas came pouring out! And it had been sitting that way all winter. The oil had been fresh and full, and I'm guessing it had about a half quart of gas that had gotten in it and sat there for about 4 months.
My question is...what damage might the gas being there in the oil for that long have caused? Is there anything I can do now to prevent damage before I move ahead and try to get it running? Can you advise me on how to proceed from this point?
Thank you any and all, for whatever you can help me with. Oh, and I apologise for the length of this post - I guess I felt the need to get this all out after a long cold winter, Thanks again.
SignGuy 50
\'83 GL1100 ASPENCADE
IT\'S ONLY ROCK N\'ROLL...BUT I LIKE IT.
SignGuy 50 is offline
post #2 of 9 (permalink) Old 03-30-2007, 11:33 PM
The gas didn't hurt anything because the engine was not running.
Just drop the old oil (you did that already), refill and a new filter and go ride.
post #3 of 9 (permalink) Old 03-30-2007, 11:44 PM
Do the 83's use mechanical or electric pumps? If mechanical you might look in to the possibility the diaphragm is leaking gas by and in to the cankcase also. If this were the case it would usually come out the vent hole but better safe than sorry I guess.
redwing52 is offline
post #4 of 9 (permalink) Old 03-31-2007, 06:36 AM
retiredintime's Avatar
Hello signguy50..Here is a link to Randakk's site with a very good section on how to start up a Goldwing after a long layup. Please do it step by step...http://www.randakks.com/TechTips.htm#24
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #5 of 9 (permalink) Old 03-31-2007, 07:34 AM
beachbuddy0253's Avatar
welcome back signguy, never give up just postpone, like they said change the oil and ride baby ride, however i would keep an eye on the oil to make sure there is no more gas in it, bad things can happen when you ride with gas in the oil. good luck
beachbuddy0253 is offline
post #6 of 9 (permalink) Old 03-31-2007, 07:55 AM
Monkey with a Football
Rudy's Avatar
In the town I used to work in, there was a guy who's family owns a local liquor store who was riding one of his Harleys down the highway when it burst into flames near the crotch.
By the time he got it stopped, got off of it and got it out, he was in some serious trouble from knee to knee and everything in between. Not a real fun injury to be revcovering from.
Fortunately, we don't ride bikes known for spontaneous combustion but loose gasoline and it's vapors should not be treated casually. Same for battery acid and bad wiring.
Rudy
wasn't too much fun”
Rudy is offline
post #7 of 9 (permalink) Old 03-31-2007, 08:21 AM
beazer's Avatar
I don't know if the GL1100 fuel pump will allow gasoline to enter the crankcase with a ruptured diaphram or not. In some engine designs, this can happen. My father once owned a 1968 Dodge pickup truck that did this. Turned out the gasoline enriched oil did a fantastic job of cleaning out the engine. The valve lifters clattered something terrible as well, until we replaced the fuel pump and drained and replaced the oil. Other than being a fire hazzard for a half a day or so while we puzzled over the symptoms, the engine ran fine for another couple of decades.
I don\'t want a pickle
Just want to ride my motorsickle.
1980 GL1100 Standard
beazer is offline
post #8 of 9 (permalink) Old 03-31-2007, 08:17 PM
Loyd's Avatar
These bikes are notorious for the float valve not sealing especially after an overhaul. It takes them a while to take a seat I guess. Most people recommend you use the original Honda float valves. I like to set my floats a little higher than the specifications (.650) not .610 as recommended. They seem to run better. It won’t hurt your motor for the gas to be in there as long as you didn’t run it. Just drain it and fill it back with oil. The 1100 is a great bike and pretty much bullet proof. Ride and enjoy
1983 Goldwing GL 1100 I Wineberry
Loyd is offline
post #9 of 9 (permalink) Old 03-31-2007, 10:30 PM
Most motorcycles with carburetors are at risk for gas in the case if a float valve leaks. Since the tank is usually well above the engine and carbs it can happen. That's why they have petcocks. When you shut down a bike it's always best to shut the fuel off.
Once an engine has been flooded with gasoline, I'd drain, change the oil and filter and run it a few minutes and then do it again. There are just too many spots in the engine that can trap the diluted oil and redilute the new oil to a lesser extent.
Gas mixed with oil in the GL1100 oil pan mudd Goldwing Technical Forum 6 07-27-2011 09:50 AM
Gas in the oil frankenpak Goldwing Technical Forum 4 03-16-2009 12:52 PM
Gas in my Oil?? sexytacoman Goldwing Technical Forum 4 08-10-2008 08:59 PM
gas in oil jerjer Goldwing Technical Forum 3 05-15-2008 09:23 PM
Gas versus Oil $$$$$$$$$$ Putt N along General Motorcycle Discussion Forum 3 09-06-2005 03:39 PM
