CB Adjustment - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 04-15-2007, 09:55 AM Thread Starter
limo$mitch's Avatar
Hello , It's me again. Still trying to put the factory CB on my 85 ASPY. Finally have all the components and after getting them all sorted out and powered up the CB sounds likethe conversation is off a tad. Went up and down a couple of channels to make sure someone wasn't bleeding over so that wasn't it. I know how to set the SWR on a conventional set up like the one on my truck, is there a way to tune this set up? I know the antenae has a adjustment on it and it looks like the multi changer box has one as well but what kind of meter is needed to do this. Also can the multi changer box be left out and the lines for the stereo and the CB be hooked up directly to each antenae?...Thanks
Mitch
Mitch Warren
1991 VMAX (mine)
1985 Aspencade (ours)
2002 VLX600(hers)
limo$mitch is offline
post #2 of 4 (permalink) Old 04-15-2007, 12:30 PM
L8ndeb's Avatar
Year: 1995
Model: Interstate
Send a message via Yahoo to L8ndeb
Mitch,
Here is how to adjust the antenna:
http://www.angelfire.com/ok4/wingman26/swr.html
And if you REALLY want to get into it:
http://home.comcast.net/~rkekeis/Cla...viceManual.pdf
Hope this helps.
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #3 of 4 (permalink) Old 04-15-2007, 04:25 PM Thread Starter
limo$mitch's Avatar
Thanks Leyton, that answers the SWR adapters question for me , I am off to Radio Shack to get them. Now if someone could tell me about hooking up the antenae without using the multichanger box I might be set. I have the box just wondering if you could connect each antenae directly to the source and get the same results.
Thanks Again
Mitch
Mitch Warren
1991 VMAX (mine)
2002 VLX600(hers)
post #4 of 4 (permalink) Old 04-15-2007, 06:14 PM
You should be able to do that, the AM/FM won't care. Might need to keep the diplexer box in the CB circuit if there's no other way to tune the VSWR without it.
CB adjustment Tank4300 Goldwing Technical Forum 27 04-08-2011 07:10 PM
floorboard adjustment 1stwing Goldwing Technical Forum 12 05-27-2009 09:41 PM
Clutch Adjustment MnGoldwingInterstate83 Goldwing Technical Forum 5 07-09-2008 09:07 PM
What is that adjustment Predator Goldwing Technical Forum 8 11-04-2007 07:02 AM
valve adjustment zimmerleemark Goldwing Technical Forum 16 05-14-2007 05:41 PM
