Leaking petcock assembly - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 06-07-2007, 10:29 PM Thread Starter
Hi, I have a 1999 GL1500SE. Gas is leaking out of the rear of the petcock assembly (from a tube that is manufactured into the assembly) when the bike is running. When I remove the tube that comes out of the left side (while sitting on the bike) the leak stops. The tube that comes out of the left side seems to be a vacuum of some sort.
Any suggestions are much appreciated.
If you open the following link, part #4 is the part I am referring to.
http://houseofmotorcycles.bikebandit.com/partsbandit/oem_schematic_view~schem_dept_id~211095~section_de pt_id~~section_dept_name~~dept_type_id~2~model_dep t_year~1999~model_dept_mfr~Honda~model_dept_id~206 271~model_dept_name~GL1500SE+%28GOLD+WING+SE%29.as p
Thanks!
Daniel
danypak is offline
post #2 of 6 (permalink) Old 06-07-2007, 11:19 PM
2 things for you.
#1 Please, but pretty please, do NOT post a long link. It destroys the forum width.
Go to http://www.tinyurl.com and insert your long link there and then use the
short link when posting on the forum. Once you have the link repaired, come back
to here and delete the long link and replace it with the new short link that Tiny
provided. The rest of us will really appreciate it. Tnx,
#2. That link is not valid. For you it may have worked because you had something in
your browser cache that aided you in getting to the link. For us, it is broke.
Now, for your problem.
Are you refering to the fuel vacuum operated petcock that is viewable from the fuel
tank filler door? If you are, then get in contact with vencowings and they can
provide you with the proper repair kit. I just bought two of them last week so
they are in stock again.
Hope this helps.
ps - to make this viewable without scrolling, I had to insert hard carriage returns.
post #3 of 6 (permalink) Old 06-07-2007, 11:21 PM
Oops....just noticed this is your #1 post.
Let me welcome you to the forum with a great big
HOWDY! friend and welcome to our place of info and fun.
Some of us (me included) are a bit off the rocker so don't put too much stock
into what we say on here. Info included.
post #4 of 6 (permalink) Old 06-07-2007, 11:24 PM
Tattoo Taffy's Avatar
part number 4 is.............. 4: PETCOCK ASSY 228511-001 $141.09
Tattoo Taffy is offline
post #5 of 6 (permalink) Old 06-07-2007, 11:26 PM
Taffy!
I am disappointed in you. That is the third straight laced, informative post
that you have made since you've been on this forum.
You sick or something???
post #6 of 6 (permalink) Old 06-07-2007, 11:28 PM
i think i am coming down with a fever........
97 GL1500 Petcock Leaking Fuel newday777 Goldwing Technical Forum 3 01-13-2011 03:23 PM
GL 1500 Petcock assembly. Took mine apart and forgot.. hallfleming Goldwing Technical Forum 15 11-08-2010 11:46 AM
GL1500 gas petcock assembly rdurand Goldwing Technical Forum 6 09-13-2010 11:08 AM
Petcock leaking on 83 Interstate in the off position. alanzdot Goldwing Technical Forum 4 04-24-2009 10:47 PM
gl1500 petcock assembly Goldwing Technical Forum 1 08-15-2008 07:41 PM
