GL1000 Stator Removal without motor removal? - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 06-18-2007, 01:58 AM Thread Starter
Thanks, I know now that the engine HAS to be removed in order to change the stator. Bob
bob007 is offline
post #2 of 5 (permalink) Old 06-18-2007, 03:35 AM
Bernieswing's Avatar
There are a lot of posts and threads about this already Bob. Good news is that you don't need to pull the engine. You may need to remove the rearmost exhaust stud after dropping the pipes an inch or so. Also, when the starter motor is loosened and just before you pull it you should drop the Wing onto the side stand. This is so that the starter sprocket won't roll out of the chain and inside the engine.
By the way, Welcome to the forum.
GL1800 SatNav, red 2006
GL1500 Aspencade, blue 1999
GL1200 Aspencade, blue 1986
Bernieswing is offline
post #3 of 5 (permalink) Old 06-18-2007, 03:40 AM
Sorry Bob, I misread your post, I thought it was about the Starter, not the Stator. Stator removal need the engine to be removed first on all the 4 cylinder Wings and I don't know of a way round this.
post #4 of 5 (permalink) Old 06-18-2007, 07:19 PM
Cal-D's Avatar
Model: Stream Silver 2007
Engine must come out.
Have Wing Will Travel
Cal-D is offline
post #5 of 5 (permalink) Old 06-18-2007, 07:26 PM
Lil Pete's Avatar
I can't say first hand as to the 1000s but, I can say first hand that on the 1100s the engine does not need to be removed.
2008 GL1800B (Airbag)
Lil Pete is offline
85 1200 Aspencade motor removal The Handyman Goldwing Technical Forum 13 04-05-2010 02:31 PM
motor removal gl1000 '77 2Dahorizon Goldwing Technical Forum 8 07-19-2009 06:05 AM
starter motor removal sabel Goldwing Technical Forum 4 03-01-2008 05:05 PM
Stator removal 85 1200 LTD JJ75 Goldwing Technical Forum 10 10-11-2007 09:32 PM
Stator Removal, thankyou everyone clubby Goldwing Technical Forum 4 03-12-2006 06:24 AM
