GL1200 Stator replacement - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 07-05-2007, 07:07 PM Thread Starter
joe1970's Avatar
Working with an 84 Aspencade 1200, The stator is in need of replacement and someone has already cut the plug out of the system and soldered the 3 yellow wires together. My question is: when I install the new stator I have no way of matching the wires to their respective positions on the new stator. Looking at the schematic, it looks as thought each of the three stator coils are the same so will it matter if the wires are connected differently than original. If so is there a way to differentiate?
joe1970 is offline
post #2 of 7 (permalink) Old 07-05-2007, 07:22 PM
quakeholio's Avatar
Send a message via MSN to quakeholio
Order dosen't matter. Probably why honda didn't color code.
Mind you, I know everything about nothing and nothing about everything.
quakeholio is offline
post #3 of 7 (permalink) Old 07-05-2007, 07:44 PM Thread Starter
joe1970's Avatar
Thanks you have eased my mind at least on this problem. I may earn one of those very active tags before this project is over. Cheers.
joe1970 is offline
post #4 of 7 (permalink) Old 07-05-2007, 10:12 PM
It's really not a bad job except for muscling the engine in and out. The Honda and Clymer manual give pretty good step by step instructions for pulling the engine.
post #5 of 7 (permalink) Old 07-05-2007, 11:11 PM
Larry G.'s Avatar
I've always wonderedwho the brilliant guy was who designed the GL1200with that frame member right square in the way of the alternator housing.
Larry G.
1985 GL1200 Interstate
Previous bikes:
1971 Suzuki Hustler 250
1973 Yamaha RD 350
1982 Yamaha Seca 650
2001 Kawasaki Vulcan 1500
Larry G. is offline
post #6 of 7 (permalink) Old 07-06-2007, 06:42 AM
dougbo's Avatar
Year: 1982
Make: Goldwing
Model: GL1100
That was to give the dealers something to repair .
Have 1982 GL1100 with a 1977 Watsonian Monaco sidecar. Live in Mesa AZ.
dougbo is offline
post #7 of 7 (permalink) Old 07-06-2007, 11:29 AM
P Yanney's Avatar
Me and a buddy did my '87 1200 the beginning of this year so I can help with any pointers. It helps to have a set of hands on both sides of the bike, mainly when the carbs, exhaust and getting the driveshaft on the output shaft. (I went with RM Stator for $139) and much better insulated than OEM. Let me know if ya need anything.
Paul
87 GL1200 Interstate
08 Harley 105 year Anniversary Custom
76 Honda CB750K
P Yanney is offline
Stator Replacement GL1200 Question tgsguitar General Motorcycle Discussion Forum 32 06-20-2012 10:56 AM
GL1200 Stator Replacement vs. Alternator Spirit-of-98 Goldwing Technical Forum 4 06-08-2012 08:14 PM
Stator replacement GL1200 rustymich Goldwing Technical Forum 23 02-15-2010 07:36 PM
STator replacement on a GL1200 Aspen Martin Fischer Goldwing Technical Forum 3 08-29-2009 10:26 AM
doing the dreaded stator replacement (gl1200) lowflyer Goldwing Technical Forum 3 06-11-2006 12:08 PM
