'86 Gold Wing - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 07-07-2007, 07:00 PM Thread Starter
My 1986 Gold Wing Interstate seems to run fine under a load, when warmed up. When ideling I bring the rpms up to around 2000, it wants to misfire. When the bike is started cold it starts right up but needs alot of choke to keep going. After it is warmed up it runs great but at a fast idle around 2000 rpm it will miss. At normal idle after warm up it idles great.
Sure could use some help on this one,
Thanks
Dgauthi is offline
post #2 of 5 (permalink) Old 07-07-2007, 11:03 PM
Check this out.
http://home.comcast.net/%7Erkekeis/Carbshimsfor1200.htm
redwing52 is offline
post #3 of 5 (permalink) Old 07-08-2007, 10:38 AM
Senior Guru
Goldwinger1984's Avatar
Do you know if anyone has messed around with the fuel mixture screws? They should have the factory covers on them.
Vic
Goldwinger1984 is offline
post #4 of 5 (permalink) Old 07-08-2007, 12:26 PM Thread Starter
In reply to both Redwing 52 and Goldwinger 1984 Senior Guru, I have looked at the link that was given by Redwing 52 and I may try this. I have noticed in my Clymer Honda manual 1984-1987 page 142 that the '84 and '85 Goldwings had an issue about running rough around 2k and should be brought in to Honda to be fixed for free. But not the '86 or '87. When I bought the bike about 10 years ago it never had this problem that I mentioned in my origional statement. I have checked everything that I could as far as compression (all are 160lbs), pulse generator resistance (both are 340 ohms), timing to see if the spark advances--ok. Spark plugs and wires, coils etc. Everything seems ok. As far as if anybody has changed the mixture settings I have no idea. Like I mentioned the bike ran fine when I bought it 10 years ago. Under a load the bike will red line to 7.5k without a miss. (From idle to red line) With no load it only misses around 2k, at red line with no load it is ok. My gas milage is always between 48-52 mpg. Maybe getting old like me. I spit and sputter around 2k also.
Thanks for the help, great to have guys like you on the net to help out
Dgauthi is offline
post #5 of 5 (permalink) Old 07-08-2007, 02:36 PM
Senior Guru
Sounds like you have a very good running bike that only misses in neutral at 2000 RPM. That's a very difficult range to tune because it could be any of the circuits in the carbs in any of the carbs if in fact it is the carbs causing the problem. It could be a vacuum leak in the hose at the #4 carb going to the ECU, that one frequently develops a leak or it could be a vacuum leak under one of the manifolds. You can check for vacuum leaks with an unlit propane torch and listen for a drop in engine RPM when you find one. The alternative is to remove the carbs and go through them thouroughly and hopefully you find something wrong but your bike runs so good that it'll be hard to find anything wrong at this time. Keep driving it and see if the condition improves or gets worse and make a decision down the road.
Vic
Probably Not For A Gold Wing... dbd123 General Motorcycle Discussion Forum 7 04-25-2010 12:10 AM
82 gold wing lilbitpepper_1 General Motorcycle Discussion Forum 10 08-17-2008 05:23 AM
Not a Gold Wing Scout Guy General Motorcycle Discussion Forum 13 07-18-2007 05:47 AM
Got My Gold Wing Wolfman Thunder General Motorcycle Discussion Forum 17 03-08-2007 09:07 PM
Gold Wing greenmotorcycler General Motorcycle Discussion Forum 47 06-22-2005 06:12 PM
