Oil seal at the water pump? - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 07-14-2007, 05:18 AM Thread Starter
Keystone742's Avatar
Year: 1984
Model: Gl1200I
After synchronizing the the carbs yesterday, I discoveredthat asmall puddle of oil had dripped out from the water pump weep. I had the bike running up on the center stand for about 45 mins.I cleaned up the oil mess, took ashort spin to verify the carb work, and parked it on the center stand. When I came back about an hour later, there was NO oil leaking. ???? I'm assuming this means the seals are starting to go on the water pump, or is it something else? Any ideas?
1984 1200I Candy Cobalt Blue over Bright Silver Metallic w/ Black & Silver Marbling. Poorboy alternator. Progressive springs and a comfy gel seat.
Keystone742 is offline
post #2 of 15 (permalink) Old 07-14-2007, 06:45 AM
Hi Keystone742 Sounds like an o-ring may be ready for replacement. I imagine the motor was a lot warmer sitting there idling for 45 minutes then it cooled down with your test ride. There are 2 o-rings on the water pump body. Depending on which ring fails determines if you are leaking oil or antifreeze.
87 GL1200I Grey
03 GL1800 Red
wingmaster is offline
post #3 of 15 (permalink) Old 07-14-2007, 08:37 AM
RB
RB's Avatar
Send a message via AIM to RB
There are actually three places the oil could come from; the screws that hold the pump on(there are washers that can leak or may be missing), the oil seal(not an o-ring it's a true seal) and last the o-rings on the back of the water pump.
read here. https://www.goldwingfacts.com/forums/forum1/28482.htm
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #4 of 15 (permalink) Old 07-14-2007, 08:42 AM
Yep, Roger should know. He got plenty of practice in before he figured out how to put those seals in without having a leak
post #5 of 15 (permalink) Old 07-14-2007, 09:42 AM
dan filipi's Avatar
Model: 1983 GL 1100 I
I would stick a piece of wire in the weep hole to make sure it's clear.
If it's clear and there isn't anymore signs of oil or coolant dripping then ride the bike every chance you get and keep an eye on it.
dan filipi is offline
post #6 of 15 (permalink) Old 07-14-2007, 04:30 PM Thread Starter
Year: 1984
Model: Gl1200I
I rodeit for a few hours today, and looked at the ground everywhere I parked. No oil spots. Of course that was using the kick stand, and it didn't leak back in the barn at home either. Of course it might be dripping while going down the road, and I'd never see it, but the underside of the motor doesn't look "wet", just dirty. So, for now I'll just keep an eye on it and order a seal kit for it and when I get the chance I'll replace the seals. She is 23 yrs old and every 23 yr. old female I know is kind of high maintenance, but well worth having.
post #7 of 15 (permalink) Old 07-14-2007, 04:58 PM
Monkey with a Football
Rudy's Avatar
Trust me, you'd see it.
Rudy
wasn't too much fun”
Rudy is offline
post #8 of 15 (permalink) Old 07-15-2007, 08:04 AM
RB
RB's Avatar
Thanks a lot AZ for reminding me!!!
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
FAIR WINDS,
RB
RB is offline
post #9 of 15 (permalink) Old 07-16-2007, 07:06 PM
gladmaker's Avatar
That link doesn't work. Can you try it again? I want to read it. Thanks
1978 GL1000
1984 GL1200
1999 GL1500 SE
Proud member of the Arkansas Patriot Guard Riders
gladmaker is offline
post #10 of 15 (permalink) Old 07-23-2007, 01:21 PM
Hi Guys,Now I have a bona-fide oil leak comming from that weep hole. I ride a 1984 A1200 with 21K on it.. I'm thinking front crank seal or some such. What's the drill on fixing it? Started about a month ago (100 miles or so). I smell it while I'm riding and it leaves about a 4 inch spot when parked. Ialso found the link to the discussion will not load.
Steve
SLSNUT is offline
water pump seal hodeman Goldwing Technical Forum 5 03-14-2010 02:31 PM
Oil Dripping out Water Pump Weep Hole, Which Seal? zowie Goldwing Technical Forum 5 05-08-2007 10:48 AM
Water pump oil seal B. J. Baum Goldwing Technical Forum 8 10-15-2006 08:27 PM
Water Pump seal replacement issue Aquilius Goldwing Technical Forum 19 10-03-2006 09:48 PM
